Why Might Experimental Gravity Measurements Differ from the Standard 9.8 m/s²?
The discussion revolves around the factors that may cause experimental measurements of gravitational acceleration to differ from the standard value of 9.8 m/s². Participants explore various influences on gravity, including altitude, Earth's shape, and environmental conditions.
  • Participants discuss the impact of altitude and distance from the center of the Earth on gravitational measurements. Some raise questions about the role of experimental errors and environmental factors like air resistance and friction. Others mention the effects of Earth's rotation and its non-spherical shape.
The conversation is ongoing, with various factors being examined. Some participants have provided insights into how gravity varies across different locations on Earth, while others are questioning the assumptions behind the standard value of gravity and its measurement.
Participants note that the gravitational force can be influenced by the composition of materials beneath the Earth's surface and that the Earth's rotation introduces additional complexities. There is also mention of how external celestial bodies may affect gravitational measurements.
Petrucciowns
The universally accepted value of acceleration due to gravity is 9.8 m/s ^2. My question is why would an experimental value differ from the accepted value. What factors would contribute to this difference?
Its not really a rigid universally accepted value. The acceleration due to gravity decreases ssllliiggghhhty as you go further from the center of the earth.
Law of universal gravitation states that [tex]F=G\frac{m_{1}m_{2}}{r^{2}}[/tex]. On earth, this would translate to differences in an object's mass and altitude.
An object's mass has nothing to do with its acceleration (unless it's massive enough to affect the gravitational field significantly). For just about any experiment that doesn't use ultra-precise instruments, friction, air resistance, and errors in instrument readings completely overwhelm any inherent differences in acceleration.
Sorry, I misread the OP. However acceleration would just be force of gravity divided by the object's mass so it condenses down to distance from center as ralilu said.
The main factors are experimental errors as Idealsrule said, but the strength of gravity does differ very slightly at different points on the Earth because of the different heights to the centre of the Earth and it also depends on the composition of the matter between the surface and centre of the Earth (which also varies at different points)
Another factor that affects gravity is the object's distance from the equator, and this is for two reasons.
The Earth isn't actually a perfect sphere.
So the distance to the center is maximal at the equator and minimal at the poles.
Another factor is the effect of Earth's rotation. From the object's frame of reference, at any point on the Earth's surface it is affected by two forces (For the sake of the following analysis I'll assume a non-massive object and uniformity of the Earth's interior). The gravitational pull, [tex]F=m\frac{(GM_e)}{r^2}[/tex], where [tex]r[/tex] is the distance to the center of the earth, and the centrifugal force as a result of Earth's rotation around its axis, [tex]F=m\omega^2 r[/tex], where [tex]r[/tex] is the minimal distance to the axis of rotation from the object's location.
Note that the centrifugal acceleration points opposite the direction of gravity, and so it weakens it.
If I recall correctly, some world records regarding the height of jumps were overturned because they were set at a high altitude near the equator.
Earth's gravity varies by about 0.4%, when you compare the poles and the equator.
Further reading: http://en.wikipedia.org/wiki/Earth's_gravity
LOL :smile:
And many other events such as running and throwing neglect the fact that little discrepancies in air resistance can affect the results much more than this lowered gravity (which would be less than 1% difference to the sea level at the poles).
And let's not forget that the Earth isn't a closed system. All other celestial bodies in our solar system (especially the moon) affect the gravity on Earth. Think of the tides...
