Einstein's Train and a simple consequence
  • Context: Graduate
  • Thread starter Thread starter robert Ihnot
    Train
The discussion revolves around Einstein's thought experiment involving a moving train and lightning strikes at both ends. Participants explore the implications of simultaneity and the constancy of the speed of light from different reference frames, including whether light signals emitted from the train meet at the center of the train or the tracks.
  • Some participants argue that light signals emitted from the moving train must meet at the center of the train, suggesting that if they did not, it would imply the detection of absolute motion.
  • Others assert that regardless of the source of the light (stationary bulbs or moving observers), the light beams will meet at the same point due to the constancy of the speed of light.
  • A participant questions the definition of "center" in the context of the tracks and the train, indicating a need for clarity on reference points.
  • Some participants propose that when considering the train at rest, the lightning strikes will meet at the center of the train, while in the moving frame, they will meet at the center of the tracks.
  • One participant emphasizes the importance of specifying the frame of reference when discussing the simultaneity of events, noting that observers in different frames will perceive the events differently.
  • Another participant highlights that the principle of relativity implies that there is no absolute motion, and all motion is relative to the observer's frame of reference.
Participants express differing views on the implications of simultaneity and the behavior of light signals in various reference frames. No consensus is reached regarding the interpretation of the events described in the thought experiment.
Participants reference Einstein's writings and the constancy of the speed of light, but there are unresolved questions regarding the definitions of "center" and the implications of different frames of reference.
robert Ihnot
This should be a simple question for this Forum: Einstein tells us that when the train is moving and the lightning flashes on both ends of the train,if it meets at the center of the tracks, it will not meet at the center of the train for the obvious reason that the train has moved off from that position.
The webmaster for Relativity for Cranks can not see the difference between the lightning bolts at rest on the tracks and light beams flashed by the conductor and the engineer on the train at equal distance from the center, instead of the exterior lightning bolts, to the middle of the train. In this second case, I say that the light flashes must meet in the center of the train otherwise we could detect absolute motion. Look at it this way: We can always consider the train at rest and the tracks as moving.
I would like someone to assure me that I have this correct, if I do. Thanks, Bob
If I read your question correctly, it sounds like the Webmaster of Relativity for cranks knows something about Relativity. If you would not listen to him I doubt you will listen to anyone here.
It does not matter if the light beams are emitted from the stationary ground or the moving train they will meet in the same place. The speed of light is independent of the speed of the emitting body.
What do you mean by "meet in the center of the tracks"? Since we are talking about the length of the track, where exactly is the center?
The webmaster is right. Add to the situation an observer on the ground, and then have the engineer and the conductor, and the stationary bulbs all emit flashes simultaneoulsy as the engineer and conductor line up with the stationary bulbs. Because of the constancy of the speed of light the paired light beams (the engineer/one bulb and the conductor/the other bulb) must remain paired as they were emitted from the same point (along the one-dimensional motion of the track) and so must meet their counterparts at the same time and at the same point (again speaking one-dimensionally along the direction of motion). There is no difference between beams emitted by tghe stationary bulbs or the moving people.
I am looking at this directly from what Einstein wrote: When we say that the lightning strokes A and B are simultaneous with respect to the embankment, we mean: the rays of light emitted at the places A and B, where the lightning occurs, meet each other at the mid-point M of the length A —> B of the embankment. But the events A and B also correspond to positions A and B on the train. Let M' be the mid-point of the distance A —> B on the traveling train. Just when the flashes 1 of lightning occur, this point M' naturally coincides with the point M, but it moves towards the right in the diagram with the velocity v of the train. If an observer sitting in the position M’ in the train did not possesses this velocity, then he would remain permanently at M, and the light rays emitted by the flashes of lightning A and B would reach him simultaneously
Well, what if we consider the train at rest and the tracks as moving?
You'll get the same result, that is the principle of relativity.
the train at rest
WEll, if the train is at rest and the engineer and the conductor both send off beams half way from the center of the train, why would they not arrive at the center at the same time, while with regards to the track this would not happen?
Your mistake is not specifying the frame of reference you are using. In my post i used the frame of reference of the stationary observer at all times. He saw the two sets of light pulses converging simultaneously at the midpoint between the two stationary bulbs.
In your statement you have switched reference frames to the train. An observer on the train sees the beams meet at the mid point between the engineer and the conductor, and not at the mid point between the bulbs on the embankment, for both pairs of beams, again because of the constancy of the speed of light.
Train at rest...
I thought that was what I had in mind. With the train system "at rest," we have no way to determine absolute motion. So maybe I was not entirely wrong, just sounded wrong. With the train at rest, the lightning bolts at rest, they meet in the center of the train. However with the train at rest, the tracks moving and the lightning bolts moving the same way, then the bolts meet in the middle of the tracks. Yes?
Yes, but you can take that further. In both cases you are talking about the frame taken to be at rest. An observer taken to be in the moving frame will see the same thing as if his frame were taken to be at rest. So there is no absolute motion. And furthermore, motion being described in terms of space and time, if there is no absolute motion, there is neither absolute space nor absolute time, all 3 must be relative to the frame of reference of the observer. All of this proceeds directly from the combination of the constancy of the speed of light for all observers and the relativity principle (and of course other assumptions too fundamental for us to consciouly take note of, despite their obvious epistemological significance)
  • · Replies 26 ·
  • · Replies 52 ·
9K
  • · Replies 22 ·
  • · Replies 58 ·
9K
  • · Replies 41 ·
  • · Replies 16 ·
  • · Replies 136 ·
16K
