Slightly off on the answer to a problem, but why?
  • Thread starter Thread starter Brianjw
The discussion revolves around calculating the forces exerted by two individuals carrying a 200 kg crate up a flight of stairs inclined at a 45.0-degree angle. The upper person's force was incorrectly calculated as 1176 N, while the correct value is 588 N, which is half due to the distribution of weight. The bottom person's force was expected to be 1370 N, but the calculations were flawed, particularly in the torque equations. The participants emphasized the importance of double-checking calculations and ensuring all forces are accounted for in the analysis.
  • Understanding of basic physics concepts such as force, torque, and equilibrium.
  • Familiarity with vector components and trigonometric functions.
  • Knowledge of the principles of static equilibrium in mechanics.
  • Ability to perform calculations involving mass, gravity, and angles.
  • Review the principles of static equilibrium and force balance in mechanics.
  • Learn about torque calculations and their application in real-world scenarios.
  • Study vector decomposition and how to resolve forces into components.
  • Practice problems involving inclined planes and forces acting at angles.
Students studying physics, particularly those focusing on mechanics, engineers involved in structural analysis, and anyone interested in understanding force distribution in practical scenarios.
Brianjw
Two friends are carrying a crate of mass 200 kg up a flight of stairs. The crate has length 1.25 m and height 0.50 m, and its center of gravity is at its center. The stairs make a 45.0 angle with respect to the floor. The crate also is carried at an 45.0 angle , so that its bottom side is parallel to the slope of the stairs . The force each person applies is vertical.
What is the magnitude of the upper person's force?
I keep getting 1176, but the answer is supposed to be 588 which is just half of my answer?
Also, for the next question:
What is the magnitude of the force applied by the bottom person?
I'm not able to get the 1370N that's its supposed to be, I'm trying to use the sum of the torques about the point of F2 which is the upper person's force, and that doesn't seem to work
Hm.. you must have made a mistake in your torque equation about the top person.
Using "t" and "b" as subscripts for the persons, [tex]\theta[/tex] as the angle to the horizontal, "l" as the length, "h" as the height, "m" for the mass, "g" as the acceleration due to gravity, [tex]\vec{t}[/tex] as the unit tangent along the bottom side, [tex]\vec{n}[/tex] as the unit normal, we have the following relations:
[tex]\vec{t}=\cos\theta\vec{i}+\sin\theta\vec{k}[/tex]
[tex]\vec{n}=-\sin\theta\vec{i}+\cos\theta\vec{k}[/tex]
[tex]\vec{k}=\sin\theta\vec{t}+\cos\theta\vec{n}[/tex]
[tex]\vec{n}\times\vec{t}=\vec{j}[/tex]
Balance of forces:
[tex]F_{b}+F_{t}=mg[/tex]
Balance of torques about the top person:
[tex]-l\vec{t}\times{F}_{b}\vec{k}+(-\frac{l}{2}\vec{t}+\frac{h}{2}\vec{n})\times(-mg\vec{k})=\vec{0}[/tex]
This should give you the correct answers.
It's possible that your calculations are slightly off due to rounding errors or incorrect assumptions. It's important to double check your work and make sure you are using the correct formulas and values. It's also possible that the answer given may have a typo or mistake. It's always a good idea to double check with a peer or instructor to verify the correct answer. As for the next question, it's important to remember that the force applied by the bottom person is not just the sum of the torques, but also includes the weight of the crate and the force applied by the upper person. Make sure to account for all forces acting on the crate in your calculations. Keep practicing and don't be discouraged, sometimes it takes a few tries to get the correct answer.
12K
