Question with large number?electron charge?
  • Thread starter graphicer89
  • Tags
    Charge
In summary, the electric charge of an electron is -1.6 x 10^-19 C and the force exerted between two electrons separated by one meter is 2.3 x 10^-28 N. This force is repulsive since the charges are of the same sign.
graphicer89
55
The electric charge of an electron is -1.6 x 10^-19 C. What is the force exerted between two electrons separated by one meter? Is it attractive or repulsive?
F= K Q1Q2 / D^2
Im horrible with large numbers and especially at negative exponents...so this is a guess
K = 9x 10^9 N x m^2/c^2
Q1 = -1.6 x 10^-19 C
Q2 = -1.6 x 10^-19 C
D= 1 m
F= 9 x 10 ^9 N x m^2 X ( -1.6x 10 ^-19 C x -1.6x 10 ^-19 C / 1^2 m)
F= 9 x 10 ^9 N x m X (3.2 x 10^19 C^2 )
F= 28.8 x 10^28 NxmxC^2...is the answer i got...
I know i am completely off but how can i do this ...this is basically math but I am just not with well large numbers...
This step is wrong. -1.6x10^-19 X -1.6x10^-19 = ?
rl.bhat said:
F= 9 x 10 ^9 N x m X (2.56 x 10^19 C^2 )
Thats the thing i don't know...do you add the exponents together??
2.56 x 10^-38?
1.6 x 1.6 = 2.56 but what about the 10^-19? do i add them or does it stay the same?
Actually now i got 2.6 x 10 ^-38...by multiplying both
2.56 x 10^-38?
This is correct.
rl.bhat said:
This is correct.
Ok so after i have 2.6 x 10^-38 is it C^2?
Well let me put what i have... F=9 x 10^9 N x m^2/c^2 X( 2.6 x 10^-38 c^2 /1 m^2)
that is what i have...do i cancel out the m^2 and c^2? from both sides? so that only the N is remaining?
Yes. Force should be in N.
Cool so if i did my calculations right...i got 2.3 x 10^-28 N am i close or am i really off? but i think this force is repulsive no? because its a positive number ...or is it attractive?
Like charges repel each other.
Exactly. The equation gives the magnitude of the force. Use the opposites attract / likes repel rule to figure out the direction.
1. What is the magnitude of an electron's charge?
The magnitude of an electron's charge is approximately 1.602 x 10^-19 coulombs. This value is considered to be a fundamental constant in physics and is represented by the symbol "e".
2. How was the charge of an electron determined?
The charge of an electron was first determined by physicist Robert Millikan in his famous oil drop experiment in 1909. He was able to determine the charge by measuring the forces acting on tiny oil droplets suspended in an electric field.
3. Can the charge of an electron be changed?
No, the charge of an electron is considered to be a fundamental constant and cannot be changed. It is an intrinsic property of the electron and remains constant regardless of its environment or interactions with other particles.
4. What is the unit of measurement for electron charge?
The unit of measurement for electron charge is the coulomb (C). This is a unit of electric charge in the International System of Units (SI) and is equivalent to the charge of approximately 6.241 x 10^18 electrons.
5. How does the charge of an electron compare to the charge of a proton?
The charge of an electron is equal in magnitude but opposite in sign to the charge of a proton. This means that the charge of an electron is -1.602 x 10^-19 C while the charge of a proton is +1.602 x 10^-19 C. This difference in sign is what allows for the attraction between electrons and protons in an atom.
