Register to reply
Shaft Torque
by pegghead
Tags: shaft, torque
Share this thread:
pegghead
#1
Aug4-09, 03:12 AM
P: 8
I have a stainless steel shaft that is 140mm x 936mm long.
I need to calculate what the maximum torque is that I can apply to this shaft. I have looked around for formulas and have just got myself confused. Could someone tell me what the formula is that i need to work this out.
Phys.Org News Partner Engineering news on Phys.org
Philips introduces BlueTouch, PulseRelief control for pain relief
3-D printing leads to another advance in make-it-yourself lab equipment
Nanoscience makes your wine better
CFDFEAGURU
#2
Aug4-09, 10:07 AM
CFDFEAGURU's Avatar
P: 723
What is the maximum torsional stress allowed for the shaft material? You will need this for the equation. Also, you need to calculate the polar moment of inertia, J, of the shaft and calculate the shafts section modulus, Z. The equation for Z is Z=J/c and c=outer diameter/2.
pegghead
#3
Aug4-09, 10:38 AM
P: 8
The figure i have for the material is 77,000N/mm^2
CFDFEAGURU
#4
Aug4-09, 10:41 AM
CFDFEAGURU's Avatar
P: 723
Shaft Torque
Ok now you can run the equation. Do you know how to calculate J?
pegghead
#5
Aug4-09, 10:42 AM
P: 8
Sorry no i dont know how to calculate J.
CFDFEAGURU
#6
Aug4-09, 10:43 AM
CFDFEAGURU's Avatar
P: 723
Do you have a book on strenght of materials?
pegghead
#7
Aug4-09, 10:45 AM
P: 8
I dont have a strength of material book.
Could yoou tell me the equations that i need.
Like T = ? ? ? ? ?
and
J = ? ? ? ? ?
CFDFEAGURU
#8
Aug4-09, 10:50 AM
CFDFEAGURU's Avatar
P: 723
Well,
T = Z*(allowable stress) where Z = J/c
J = PI/2(r^4) if the shaft is solid. Is the shaft solid?
r = c = Outside Diameter/2
Think you can handle the rest?
CFDFEAGURU
#9
Aug4-09, 10:57 AM
CFDFEAGURU's Avatar
P: 723
Lastly, be sure to check and make sure all of the units are correct. You should end up with N-mm
Thanks
pegghead
#10
Aug5-09, 05:47 AM
P: 8
I have calculated the torque using the formulas given and i get 3.5E-5 Nmm of torque that a 140mm shaft can transmit when material allowable stress is 77,000N/mm^2.
I think somewhere i have miscaculated, i have checked a couple of times and got the same result.
O/D = 140mm
R = 70mm
Allowable stress = 77,000N/mm^2
The amount of Torque transmittable seems very low.
CFDFEAGURU
#11
Aug5-09, 07:43 AM
CFDFEAGURU's Avatar
P: 723
Check your math.
I have 4.15x10^7 N-m
That is a lot of torque.
pegghead
#12
Aug5-09, 07:51 AM
P: 8
the figure i am getting for J is around 6.5E-8
Q_Goest
#13
Aug5-09, 07:55 AM
Sci Advisor
HW Helper
PF Gold
Q_Goest's Avatar
P: 2,907
Check the allowable stress. It's about 2 orders of magnitude higher than a strong grade of steel.
pegghead
#14
Aug5-09, 07:59 AM
P: 8
The allowable stress figure that i have is 77KN/mm^2.
CFDFEAGURU
#15
Aug5-09, 08:00 AM
CFDFEAGURU's Avatar
P: 723
For J,
J = PI/2(r^4) = 3.141592/2*(70^4) = 1.570796*(24010000)=37714811.96 mm^4
CFDFEAGURU
#16
Aug5-09, 08:12 AM
CFDFEAGURU's Avatar
P: 723
Are you using all the correct units?
pegghead
#17
Aug5-09, 08:12 AM
P: 8
I know where i was having problems it was in the formular, i was dividing Pi by 2x(r^4) and not Pi/2 x (r^4).
I get a result of 26534.37mm^3 for Z.
However when i now multiply this by the 77,000N/mm^2 i get 2043146490Nmm. Not the 4.15x10^7 that you got.
Register to reply
Related Discussions
Size shaft is required to transmit 100 Hp @ 1000 rpm Engineering, Comp Sci, & Technology Homework 3
Percentage saving in weight of sloid shaft Vs hollow shaft Engineering, Comp Sci, & Technology Homework 2
Percentage saving in weight of Hollow Shaft vs Solid Shaft Engineering, Comp Sci, & Technology Homework 24
How to compute for the torque developed in the shaft of the motor? Engineering, Comp Sci, & Technology Homework 0
Solid shaft Engineering, Comp Sci, & Technology Homework 1
