Methods of laboratory fatigue testing?
The discussion revolves around methods of laboratory fatigue testing, focusing on various techniques used to assess the endurance strength of materials. Participants explore different testing methods and the types of results that can be expected from these tests.
  • Experimental/applied
  • Homework-related
  • One participant mentions non-destructive testing methods including oil and chalk (dye penetrants), magnetic particle testing, ultrasonics, and radiography.
  • Another participant, Dave, suggests that rotating-bending fatigue is a straightforward lab bench test method, often employing a staircase method and statistical analysis. He notes that tensile load cells can be used for fully or partially reversed cyclical loading.
  • Dave emphasizes that rotating-bending fatigue is among the cheapest and simplest methods for determining endurance limits.
  • A later reply asks about the expected results from these testing methods, indicating a focus on the number of cycles a specimen can withstand under stress.
  • One participant outlines that results typically include the number of cycles and the applied stress (in MPa or other units), suggesting that multiple samples (at least 12-16) are usually tested.
Participants present multiple methods for fatigue testing, and while there is some agreement on the types of tests and expected results, no consensus is reached on a definitive list of methods or the best approach to fatigue testing.
The discussion does not resolve the specific assumptions or conditions under which each testing method is applied, nor does it clarify the limitations of the proposed methods or results.
Readers interested in materials science, engineering testing methods, or those preparing for assessments related to fatigue testing may find this discussion relevant.
student_
Methods of laboratory fatigue testing??
I have had a try at this question but don't think the answer was enough. Can someone please check it and give me the correct answer.
Question
Outline the methods of laboratory fatigue testing and the results likely to be obtained. (10 marks)
Answer
Non-destructive testing:
  • Oil and chalk (dye pedentrants)
  • Magnetic particle
  • Ultrasonics
  • Radiography
There's lots of ways to test fatigue or endurance strength of materials. Rotating-bending fatigue is a nice and easy lab bench test method, usually people use a staircase method and then apply a statistical analysis. You can also use some tensile load cells that allow either fully reversed cyclical loading, or partially reversed cyclical loading.
I'd add these in, as these are the cheapest (RBF) and simplest methods of determining endurance limit.
Cheers,
Dave
Cheers,
Dave
Thanks Dave,
Do you know the kind of results likely to be obtained from these testing?
What you do is place a test specimen under a stress and see how many cycles it lasts. So your results will be:
# of Cycles
Stress (MPa or other)
Then you do multiple samples usually at least 12-16.
Cheers,
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 19 ·
11K
