Find Resting Distance of Spring with Tension & Constant
The discussion focuses on calculating the resting distance of a spring under tension using Hooke's Law. Given the current distance and the spring constant, the extension can be determined. The basic spring equation, F = kx, where F is the force, k is the spring constant, and x is the extension, is essential for this calculation. The block's movement is constrained to the y-direction, which simplifies the analysis.
  • Understanding of Hooke's Law
  • Knowledge of spring constants
  • Familiarity with basic physics concepts of force and motion
  • Ability to perform algebraic calculations
  • Study the application of Hooke's Law in various spring systems
  • Explore the concept of static and dynamic equilibrium in physics
  • Learn about the effects of tension on spring behavior
  • Investigate real-world applications of spring constants in engineering
Physics students, mechanical engineers, and anyone interested in understanding the mechanics of springs and tension systems.
Toonzaka
If a Spring is encountering a Tension within it. And you know the distance it is currently at and the Spring Constant, is there a way to find out what the resting distance of the spring is? Also noting that the block attached to the spring can only move in the y direction.
Welcome to PF!
Hi Toonzaka! Welcome to PF! :wink:
Yes, if you know the force and the spring constant, then the basic spring equation will give you the extension …
have a go! :smile:
  • · Replies 30 ·
  • · Replies 24 ·
