How do 'Plasma Windows' create vaccums?
  • Context: Graduate
  • Thread starter Thread starter Chaos' lil bro Order
    Windows
Plasma windows are created by manipulating plasmas at temperatures of 12,000°F using electric or magnetic fields. These plasmas can be shaped into a planar, square form that acts as a barrier within an airtight chamber. This configuration allows for the creation of a vacuum by effectively sweeping dust and particulate matter to one end of the chamber, where it is expelled through a valve. The discussion highlights the innovative use of plasma technology in vacuum creation.
  • Understanding of plasma physics and its properties
  • Familiarity with electric and magnetic field manipulation
  • Knowledge of vacuum chamber design and operation
  • Basic principles of thermodynamics related to high temperatures
  • Research the principles of plasma physics and its applications
  • Explore electric and magnetic field manipulation techniques
  • Study vacuum chamber design and the creation of vacuums
  • Investigate the thermodynamic properties of materials at high temperatures
Physicists, engineers, and researchers interested in advanced plasma applications and vacuum technology.
Ok, so physicists can create plasmas in a chamber with a temp. of 12,000F. Plasmas are easily manipulated with electric or magnetic fields. One type of manipulation shapes the plasma into a planar ,square shape like a window pane, called a 'plasma window'. These plasma windows can be used inside an air tight chamber to create a vacuum within this chamber. My question is how? My imagining is that the plasma window fills one entire side of the chamber then is pushed forward through the chamber, essentially 'sweeping' all the dust and particulate material to the far chamber end where the plasma forces it out through a valve which is then closed.
hmm 136 no replies, too niche question?
I imagine it would have to be something like the process you described.
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 39 ·
17K
11K
