Chargedistribution from a given potential
  • Thread starter Thread starter eXorikos
    Potential
The discussion revolves around determining the charge distribution from a given electrostatic potential, specifically in the context of a charged dielectric situated between two charged plates. Participants are exploring the relationship between the potential and charge density, referencing relevant equations and concepts from electrostatics.
  • Participants are attempting to relate the potential to charge distribution using the second derivative of the potential. Questions arise regarding the specific form of the potential and how to apply the relevant equations, such as Gauss's law.
There is an ongoing exploration of the mathematical relationships involved, with some participants providing hints about using the second derivative to find charge density. However, there is a lack of consensus on the exact form of the potential needed for calculations, and multiple interpretations of the problem are being discussed.
Participants mention constraints such as the need for an analytical formula for the potential and the challenge of approximating the given potential for differentiation. There is also a reference to the potential being represented graphically, which may limit the information available for calculations.
eXorikos
The following potential is given
The question is what the charge distribution is. The middle part is a charged dielectric. The two discontinuous points are the result of a charge accumulated in one point. And after that point the potential doesn't vary. So my thoughts are that the physical situation is a charged dielectric between two charged plated, with the charges of the dielectric oposite to the charge on the plate it faces.
I think I'm right so far. But now I want to calculate the charge distribution. The hint was to use delta-function and I can see why, but I don't know how. Can any of you help me?
PS: My paint skills suck, but I hope it's clear that the middle parabolic and the left potential is higher than the right one.
eXorikos said:
The following potential is given... The question is what the charge distribution is.
Use the equation ∆φ ~ ρ. In a 1D case the second derivative of your potential will give the charge density.
But what is the equation for such a potential?
Sorry, I should have written it as ρ ~ ∆φ (Gauss law) or ρ(x) ~ (d²/dx²)φ(x) in your case.
ρ is a charge density and φ is the electrostatic potential. Depending on units, the equation may contain 4π, etc.
I know how to solve a laplacian, but I can't find the equation for the potential.
The equation is the following: ρ(x) ~ (d²/dx²)φ(x) in your case. All you have to do is to differentiate twice your potential given in your figure.
I know all that. I've studied my book (Introduction to Electrodynamics), but I need the equation for the potential. That's my problem...
You mean an analytical formula for your curve in the figure? Approximate it with something differentiable and you will obtain an approximate charge density.
The differential equation for a potential is the Gauss law ∆φ ~ ρ.
If the charge density ρ is given, you have to integrate this differential equation to find the potential φ.
If the potential φ is given, you have to differentiate it to find the density ρ.
  • · Replies 30 ·
  • · Replies 22 ·
  • · Replies 21 ·
