Breaking Bonds in Space: Understanding UV Radiation's Effects on Covalent Bonds
  • Thread starter ania 5555
  • Tags
    Space
In summary, the rate of Kapton film loss in space is 3.5x1020 AO/cm2/s. If the film is 1cm thick, it will last attack by AOs for 3.04 x 10-24 cm3/AO.
ania 5555
Please can you help me with these question;
1)Which bonds can be broken by UV radiation in space?
I've done it but I'm not sure if this is correct.
Covalent bond can be broken by UV radiation in space such as; O-O, N-N, C-N, C-C,
C-O, and double pi bond C=C
2)Consider an area (A) of Kapton that is 1cm2. Assume (i) that the flux of AOs (F) is 2.5 x 1020 atoms/cm2/s and (ii) that 3.04 x 10-24 cm3 Kapton is removed per AO (RE: reaction efficiency). Then the rate of loss of film thickness (x) (- dx/dt=A x F x RE) is (3.5x1020 AO/cm2/s) x (3.04 x 10-24 cm3/ AO). What is the rate of Kapton film loss in space? If the film is 1cm thick, how long will it last attack by AOs if the rate remains constant?
AO- atomic oxygen
3)If the rate of adsorption (dθ/dt) is kax p02 x (1-θ) exp (-Ea/RT) what is the time for a 1m2 window to be covered by O2 at an altitude of 300km above the Earth’s surface?
4)Suggest one object that would be better produced in space than on Earth??
Welcome to PF :smile:
You'll have to show an attempt at solving HW problems before receiving help (forum policy).
Also, it's better to make a separate thread for each question. If we had a running discussion involving 4 separate problems in one thread, it could get pretty confusing as to who is talking about which problem.
1) If the rate of adsorption (dθ/dt) is kax p02 x (1-θ) exp (-Ea/RT) what is the time for a 1m2 window to be covered by O2 at an altitude of 300km above the Earth’s surface?
surrey physical haha
What is "Outer Space 10^3 to 10^9"?
Outer Space 10^3 to 10^9 refers to the vast expanse of space beyond Earth's atmosphere, ranging from 1,000 kilometers to 1 billion kilometers away from our planet.
What is the significance of this range in outer space?
This range encompasses a wide variety of celestial bodies and phenomena, including planets, moons, asteroids, comets, and other objects. It also includes the Kuiper Belt, a region of icy objects beyond the orbit of Neptune, and the Oort Cloud, a hypothetical cloud of comets surrounding the solar system.
How do scientists study outer space within this range?
Scientists use a variety of instruments and techniques to study outer space within this range. These include telescopes, both ground-based and space-based, as well as spacecraft and probes that can travel to and gather data from these distant regions.
What have scientists discovered within this range of outer space?
Scientists have made numerous discoveries within this range of outer space, including the identification of new planets and moons, the study of the composition and evolution of these bodies, the discovery of new cosmic phenomena, and the understanding of the origins and structure of the universe.
What are some current research and exploration efforts in outer space within this range?
Some current research and exploration efforts in outer space within this range include studying the potential habitability of exoplanets, investigating the composition and dynamics of asteroids and comets, and exploring the outer regions of our solar system through missions such as New Horizons and Voyager.
