Understanding Time Dilation Equations: Special vs. General Relativity
  • Context: Graduate
  • Thread starter Thread starter Zman
    Flow Span Time
The discussion revolves around the understanding and application of time dilation equations from both special relativity (SR) and general relativity (GR). Participants explore the definitions and implications of proper time and coordinate time in the context of these theories.
  • One participant presents the time dilation equations from SR and GR, suggesting that as velocity approaches the speed of light, time dilation occurs, affecting the perception of time spans.
  • Another participant corrects the first, indicating that the notation used for proper time and coordinate time was reversed, clarifying that proper time is measured by the moving clock while coordinate time is measured by the observer.
  • There is a discussion about the implications of gravitational time dilation, where clocks closer to a massive body run slower compared to those at infinity, with one participant asserting that both equations deal with time spans.
  • A later post seeks confirmation on the correct usage of proper and coordinate time in the context of the Lorentz factor and the Schwarzschild metric, presenting equations for both but leaving the correctness of the definitions open for discussion.
Participants generally agree on the equations for time dilation but exhibit disagreement regarding the interpretation of proper time and coordinate time, as well as the implications of these concepts in different scenarios.
There are unresolved aspects regarding the definitions of proper and coordinate time, as well as the implications of time dilation in both SR and GR contexts. Participants have not reached a consensus on these interpretations.
Zman
I would like to know if I have understood the following or not;
There are two time dilation equations that I am using;
One from special relativity, involving the Lorentz factor;
[tex]t = \frac{t_0}{\sqrt{1 - v^2/c^2}}[/tex]
And one from general relativity, the Schwarzschild metric;
[tex]t = t_f{\sqrt{1 - 2GM/rc^2}[/tex]
In the SR scenario, to is the observer's clock and t is the moving body’s clock.
As v gets bigger (approaches c), t becomes bigger.
But as this indicates time dilation t’ and to must represent time spans.
In the GR scenario, as a small body approaches a large body, the small body’s clock dilates. The reference clock in this case is at infinity and is represented by the symbol tf. This clock is analogous to the observer’s clock in the SR scenario.
But as r gets smaller t gets smaller, so in this case it is dealing with ‘relative Time Flow’ as opposed to ‘relative Time Span’.
Where Time Span = 1/ Time Flow
Does this sound right?
[tex]t = \frac{t_0}{\sqrt{1 - v^2/c^2}}[/tex]And one from general relativity, the Schwarzschild metric;
You've got it backwards there--if we have two events which occur on the worldline of a clock, then t0 is the time between events as measured by the clock itself, while t is the time between the same events as measured in the observer's frame where the clock is moving.
Yes. For example, if a clock is moving at 0.6c relative to an observer, and between two events on its worldline it ticks forward by t0 = 20 seconds, then in the frame of the observer the time interval between these events is a larger t = 25 seconds, meaning the observer perceives the moving clock to have been running slow during those 25 seconds.
Yes, the clock at some finite r will tick less time between two events on its worldline than the time between these events as measured in Schwarzschild coordinates, a coordinate system where the clock at infinity keeps pace with coordinate time. In other words, clocks closer to the source of gravity run slower in Schwarzschild coordinates. See also the outside a non-rotating sphere section of wikipedia's gravitational time dilation article.
Both equations deal with time-spans.
Yes I did get the SR equation backwards.
Completely fundamental and I had it back to front.
Thanks for your help.
I had assumed that the subscript ‘o’ into stood for the (stationary) observer’s clock and not the time recorded on the moving clock which is time dilated relative to the observer’s clock.
Can it be confirmed whether I have used Proper and Coordinate Time correctly below;
Lorentz factor;
[tex]CoordinateTime = \frac{ProperTime}{\sqrt{1 - v^2/c^2}}[/tex]
[tex]ProperTime = CoordinateTime{\sqrt{1 - 2GM/rc^2}[/tex]
Cheers and thanks
Zman
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 79 ·
  • · Replies 115 ·
10K
  • · Replies 20 ·
  • · Replies 32 ·
