General question about floating/sinking objects
  • Context: High School
  • Thread starter Thread starter astonmartin
    General
The discussion centers on the principles of buoyancy, specifically the behavior of objects submerged in water. It concludes that an object's ability to float or sink is determined by its density relative to the water. An object that "hovers" at different depths, such as 10 ft versus 20 ft, experiences slightly different water densities due to pressure and temperature changes, but these differences are minimal. Rigid objects with the same density as water will maintain their position regardless of depth, although slight compression may occur at greater depths.
  • Understanding of buoyancy principles
  • Knowledge of density and its impact on floating/sinking
  • Familiarity with water properties, including temperature and pressure effects
  • Basic physics concepts related to fluid mechanics
  • Research the effects of pressure on object density in fluids
  • Explore the relationship between temperature and water density at various depths
  • Study the principles of fluid mechanics, focusing on incompressibility
  • Investigate real-world applications of buoyancy in engineering and design
Students of physics, engineers, and anyone interested in understanding the principles of buoyancy and fluid dynamics.
astonmartin
Ok so I understand that whether an object floats or sinks depends on its density vs the density of the solution, and an object that neither floats nor sinks (sorta hovers in the middle) probably has the same density as the solution.
My question is: is there any difference between an object that "hovers" 10 ft below the surface of the water vs one that reaches equilibrium 20ft below (neither touching the bottom of course)?
Hi astonmartin! :smile:
astonmartin said:
… is there any difference between an object that "hovers" 10 ft below the surface of the water vs one that reaches equilibrium 20ft below (neither touching the bottom of course)?
Not really …
the extra pressure might crush it a little, so that might change its volume,
but water itself is generally taken to be incompressible, so a rigid object with the same density as water should "hover" at whatever depth you carefully place it. :smile:
Water is slightly denser at that depth, a tiny bit due to compression and a bit more due to its temperature, which falls off rapidly with depth. That might make a difference, but a subtle one.
11K
  • · Replies 35 ·
