Role of Capacitors in Automotive Ignition, Power Supply & Radio Tuning
  • Context: High School
  • Thread starter Thread starter logearav
    Capacitors
The discussion centers on the role of capacitors in automotive ignition systems, power supplies, and radio tuning. Participants explore how capacitors function in these contexts, including their impact on voltage fluctuations, sparking elimination in ignition systems, and resonance in radio circuits.
  • Some participants inquire about how capacitors eliminate sparking in ignition systems and reduce voltage fluctuations in power supplies.
  • One participant explains that adding a parallel capacitor can smooth out voltage fluctuations by preventing abrupt changes in voltage.
  • A simulation of an old automobile ignition circuit is presented, illustrating the role of a capacitor in charging and discharging during the ignition process.
  • Another participant discusses the importance of external capacitors in controlling resonant frequencies in ignition coils, preventing unwanted electromagnetic radiation.
  • Capacitors are described as essential components in tuning radio circuits, where they work with inductors to establish resonance, allowing for frequency selection.
  • Some participants note that capacitors in power supplies are sized to provide low resistance to AC ripple voltage, effectively filtering the output.
  • There is a discussion about whether modern transistorized ignition systems still utilize capacitors, with conflicting views on their necessity for energy storage versus EMI suppression.
  • One participant asserts that all ignition circuits, old and new, include capacitors to manage resonant frequencies, while another challenges this by stating modern systems do not require capacitors for energy storage.
Participants express differing views on the necessity and function of capacitors in modern ignition systems, with some asserting their continued relevance for energy storage and others claiming they are primarily for EMI suppression. The discussion remains unresolved regarding the exact role of capacitors in contemporary systems.
Some statements rely on assumptions about circuit design and component interactions that may not be universally applicable. The discussion includes references to specific circuit configurations and simulations that may not encompass all variations in automotive ignition systems.
logearav
dear revered members,
could u people let me the know the role of capacitors in the ignition system of automobile engines? how they eliminate sparking in ignition system
2) how they reduce voltage fluctuations in power supplies
3) how they are used in tuning radio circuits
thanks in advance
(2) Although capacitor current can jump abruptly to a new value (since it is the rate of charge flow), the voltage across a capacitor cannot jump abrupty (since capacitor voltage is proportional to the amount of charge accumulated, and the movement of charge takes some time.) So if you have a voltage that keeps jumping up and down, adding a parallel capactor will make it smoother.
Hi Logearav-
Here is a simulation of an old automobile ignition circuit.
In the thumbnail is a simulation of an old automobile ignition circuit, in common use before they were transistorized in the 1970’s. V1 is a 12 volt battery. R1 is a 12-ohm series resistor that limits the battery current to about 1 amp. L1 is the ignition coil primary, about 2 milliHenrys. S1 is a switch representing the “breaker points” that is opened and closed by a cam inside the automobile distributor. Across the breaker points is a 0.02 microFarad capacitor (“condenser”) that is shorted out when the points are closed. V2 is just a power supply that I am using to open and close the points.
The red curve represents the voltage across the points. It is 0 volts when the points are closed. When the points are closed, the coil current charges up to 1 amp, limited by the series resistor. At 2 milliseconds, the points open, and the voltage shoots up to about 300 volts, across both the capacitor and the ignition coil primary. The coil and capacitor represent a series resonant circuit with a resonant frequency of about 25,164 Hz (please check my math). Because the ignition coil has a 1:100 turns ratio, the voltage on the coil secondary would be about 30,000 volts. At 4 milliseconds, the points close, and the capacitor is shorted out until they open again at 6 milliseconds. If you look carefully at 4 milliseconds, and again at 8 milliseconds on the trace, you can see a 12 volt step when the points close.
Bob S
There is always some capacitance in any circuit. In the case of an ignition coil, most of the stray capacitance is between various windings. Without the external capacitor, there would be many different resonant frequencies (because of those random stray capacitances) and because those capacitances are of rather low values, the resonant frequencies are so high that the other parts of the circuit can't respond as they should AND there would be more unwanted (and energy-wasting) EM radiation. So an external cap is added to force a single resonant freq and at a more suitable low freq.
thanks in advance
They are used in conjunction with an inductor and make use of resonance in the circuit. This is known as an LC circuit. The resonance is set up by the continuous charging and discharging of the capacitor through the inductor. As the charge flows through the inductor a magnetic field is set up. Once the charge is equal on both plates of the capacitor, the current continues to flow, taking energy from the magnetic field. This means that a charge builds up on the opposite side of the capacitor. The frequency at which this happens depends on the values of inductance and capacitance. A variable capacitor is usually used in radios to change this resonant frequency. Because all frequencies other than the resonant frequency are quickly killed, selection of a specific frequency is made possible.
In general you can say that a capacitor blocks Dc and passes AC. To AC a cap is like a variable resistor, the value of the resistance depends on the size of the cap and the frequency of the AC. In a power supply caps are sized to be a low resistance to 120 Hz, This serves as a low resistance to ground for the AC ripple voltage created by the source voltage and the rectifier circuit.
Hi Logearav-
I attach a url to a description of an old vacuum tube regenerative AM radio circuit:
http://www.schmarder.com/radios/tube/1-30.htm
There are several pictures, and a schematic at the bottom. The thing on the left in the first picture is a parallel phate tuneable capacitor. In the last picture, a tuneable parallel plate capacitor (about 30 picofarads to 365 picofarads) is used with an RF coil (inductor) to create a parallel-resonant RF circuit (0.55 to 1.60 MHz) that is coupled to the antenna to create a grid drive signal. The round thing in the middle is a vacuum tube. Instead of an emitter, base, and collector, it has a cathode, grid, and plate.
Bob S
Thanks to all the members who helped clarify my doubt
In old style ignition systems with mechanical points, unwanted voltage and current spikes cause unwanted sparking at the mechanical contact points while delivering charge to the spark plugs where a spark is required. In modern electronic ignition systems manual contact points are elimnated.
The old mechanical points were a bit of a hassle because the points pitted (hole in one side, build up of metal on the other) and as they wore away the timing of the current delivery was changed causing a reduction in engine performance. Parallel capacitors served to reduce spikes across the points extending their life. In some applications, like outboard engines, the points were hidden away inside the flywheel and were a hassle to get to for adjustment; much easier to get into distributor caps in automobiles where such points were housed.
Naty1 said:
In old style ignition systems with mechanical points, unwanted voltage and current spikes cause unwanted sparking at the mechanical contact points while delivering charge to the spark plugs where a spark is required. In modern electronic ignition systems manual contact points are elimnated..
Is there still a capacitor in modern transistorized ignition systems? Where is it? Is the spark energy still stored in the ignition coil as a current, or in the capacitor as a voltage (like the old capacitor discharge systems with a DC-DC converter)? See Mark Ten B capacitor discharge system schamatic here:
http://www.selectric.org/delta/markten24.jpg
Yes to all above questions. The new ckts are practically the same as far as the business components go. Its just that the contacts were replaced with a solid state switch. In that ckt you reference, the .01uF on the output is the "condenser" for that coil.
Actually, no. Modern ignition systems don't need caps to store energy for the spark; any caps in the circuit are generally for EMI suppression.
Post 4 and the prior post to this explain the different use of capacitors in modern ignition systems...
This simply isn't true. A capacitor can't help but store energy if it ever sees any voltage at all. If a circuit has a cap (unless both leads are tied together!), then there is a cap storing energy. You will be unable to find an ignition ckt that does not have a cap across the coil because all automobile ignition coil ckts, both old and new, have a cap across the coil to lower and unify the resonant frequency for the coil. Without the cap, there would be resonances based on the stray capacitance, which would be too high in freq (exceeding the response of other components and causing EMI) and would spread the energy over different frequencies, unpredictably reducing the peak voltage.
Please read more carefully. I said the cap does not store energy for the spark. All the energy for the spark is stored in the B-field of the coil.
No, the energy for the spark oscillates between the cap across the coil and the coil. That's how a parallel resonant ckt works.
You are correct in stating that the spark oscillates between the coil and the capacitor. But if you look carefully at the circuit diagram in my post #4*, you will see that the energy is stored in the coil while the switch (breaker points) is closed, and released when the switch opens. This is the basis for all the automotive ignition systems from about 1930 to about 1970. This is less efficient than storing the energy in a capacitor, and triggering a solid state switch. This is the basis for the first CD (capacitor discharge) ignition kits that became available in the mid 1960's.
{Edit] * Sorry, Post #3, not #4.
CDI discharges the cap through the coil primary; there is still no significant capacitance across the secondary, regardless of what fleem incorrectly claims.
Ah I see now. By "spark energy stored in a capacitor" you actually mean "spark energy stored in the capacitor first instead of second". Thank you for clarifying.
If you take a close look at your quote that I included in the top of my post, you'll see that I was responding to your statement that caps in CDI ckts are strictly for EMI suppression.
That statement is incorrect.
I thought I clearly explained why it is incorrect, but perhaps I didn't. I'll try again with different wording and more detail this time. Please read carefully before responding.
There are stray capacitances in the windings of the coil. The capacitances vary and exist between different windings. Each capacitance and winding is a separate LC ckt and has a separate resonant frequency. If we allow each of those LC ckts to oscillate, the output signal will be a mixture of all those oscillations. The probability that all those oscillations will constructively interfere and produce a strong voltage spike is very low. The solution is to forcibly cause the resonant frequency of the system to be much lower than those separate LC ckts would have, so that all the energy is in phase and you get a strong pulse of voltage. CDI ckts most certainly do have a cap across the coil just as the old flyback ckts did, and for exactly the same purpose.
Please look at my SPICE simulation in post #3. It is a series resonance. I worked on these ignition circuits many times.
Ignoring the limiting resistor (which I'm sure you'll agree is only for current limiting and not so much the point here), that is a parallel circuit, not a series circuit. The battery impedance is zero (theoretically, of course), which means the impedance between the top of the coil and bottom of the cap (except for the limiting resistor), is zero. So the top of the coil is connected to the bottom of the cap, AC-wise. Thus they are in parallel as far as AC goes (after the switch opens and they resonate).
fleem said:
Ignoring the limiting resistor (which I'm sure you'll agree is only for current limiting and not so much the point here), that is a parallel circuit, not a series circuit. The battery impedance is zero (theoretically, of course), which means the impedance between the top of the coil and bottom of the cap (except for the limiting resistor), is zero. So the top of the coil is connected to the bottom of the cap, AC-wise. Thus they are in parallel as far as AC goes.
See example of series resonance in
http://hyperphysics.phy-astr.gsu.edu/HBASE/electric/serres.html
BTW, in some cars, the external series limiting resistor is shorted out when the car is starting.
Uh, no. You don't know what you're talking about; that IS a series-resonant circuit that Bob posted.
EDIT: Not you, Bob. I was addressing fleem's prior post. You snuck in while I was posting. Weird that we posted the same reference.
Rather than argue whether we should call a "series" circuit with its ends connected (AC-wise), "a parallel circuit" or not, let's back up to the reason bob wants to describe it as a series ckt. He did so as a refute of my statement that the cap is across the inductor--apparently as an argument that the cap is not across the inductor. The cap is most certainly across the inductor (AC-wise) in the ckt bob posted (except for the limiting resistor). So the cap and inductor trade all the energy in that resonant ckt. Call it a series ckt with its ends connected if you like, I normally call an inductor with each of its leads connected (AC-wise) to leads of a capacitor, a parallel ckt, and that is exactly how it should be analyzed--as a parallel ckt. That cap and coil are in parallel AC-wise, which is all that matters in a discussion of AC! They are a "tank" ckt, and if you tell an electronics engineer that a tank ckt isn't parallel, but really its a series ckt that has been shorted out, they'll look at you kinda funny-like, I assure you.
EDIT: Or do you disagree that the impedance between each lead of the inductor to a corresponding lead of the capacitor is not zero (except for the limiting resistor, of course)?
fleem said:
The cap is most certainly across the inductor (AC-wise) in the ckt bob posted.
No. It is not. It is series, period.
This talk of series circuits being parallel "AC-wise" is nonsense.
Would you mind telling me what you think is the impedance between the top lead of the inductor and the bottom lead of the capacitor (assuming the limiting resistor is 0 ohms)? Its a very easy question.
That would be the complex sum of the impedances of the capacitor and the inductor in question. We wold never consider the voltage source to have a zero impedance; that would be stupid.
Points closed: Z = R + jwL (R = internal coil primary resistance)
Points open: Z = R + jwL - j/wC
R is roughly 6 ohms for a 12 volt electrical system.
You seem to have neglected the impedance of the battery. Hint: its zero.
  • · Replies 52 ·
  • · Replies 17 ·
  • · Replies 28 ·
13K
