How Does Adding a Resistor Affect Capacitor Charging Time?
  • Context: Undergrad
  • Thread starter Thread starter 101nancyma
    Capacitors Circuit
Adding a second resistor in series with a capacitor increases the time it takes for the capacitor to charge to a specific voltage. In the discussed scenario, a capacitor initially charges to 2V in 2 seconds with one resistor. Introducing an additional identical resistor results in a longer charging time due to reduced current flow, as the total resistance in the circuit increases. The voltage across the capacitor will always be lower at any finite time compared to the case with a single resistor, but it will eventually reach the supply voltage as the current approaches zero.
  • Understanding of RC (Resistor-Capacitor) circuits
  • Knowledge of Ohm's Law and voltage drop across resistors
  • Familiarity with capacitor charging equations
  • Basic circuit analysis skills
  • Study the time constant of RC circuits and its impact on charging times
  • Learn about the mathematical model for capacitor charging, specifically the formula V(t) = V0(1 - e^(-t/RC))
  • Explore the effects of different resistor values on charging behavior
  • Investigate practical applications of RC circuits in timing and filtering
Electronics students, circuit designers, and engineers interested in understanding capacitor behavior in RC circuits and optimizing charging times.
101nancyma
HELP!Capacitors in circuit
Hey guys, I have a short question here. If a resistor and a capacitor are connected in a series, it takes 2 seconds for the capacitor to to have a voltage of 2V, what happen to the voltage across the original capacitor if another same resistor is added in series? The answer is that it takes longer time for the voltage to reach 2V. I don't quite understand here since I thought the second resistor is going to consume some voltage, so the voltage of the capacitor will drop.
Thanks
Voltage can't be consumed. There is a voltage difference (or drop) across a resistor when current is flowing; the magnitude is proportional to the resistance and the current.
At any finite time, the voltage across the capacitor is always lower in the second case, as you intuited. Eventually, though, the capacitor charges up to essentially the full supply voltage, and the current (and the voltage drops across the resistors) is zero. Does this help in figuring things out?
Thanks
The higher the resistance the smaller the charging current and so the longer the time it takes for the capacitor to charge.As charging proceeds the voltage across the capacitor increases as the current and the voltage across the resistive part of the circuit decrease.
  • · Replies 19 ·
  • · Replies 26 ·
