Force necessary to support mass on Hydraulic Jack???
by jumpingjack90
Tags: force, hydraulic, jack, mass, support
jumpingjack90
jumpingjack90 is offline
#1
Aug17-09, 04:38 PM
P: 14
Piston 1 in the figure has a diameter of 1.31 cm. distance of 2 in
Piston 2 has a diameter of 7.91 cm. distance of 10 in
In the absence of friction, determine the force F, necessary to support an object with a mass of 904 kg placed on piston 2. (Neglect the height difference between the bottom of the two pistons, and assume that the pistons are massless).
2. Relevant equations
F1*d1 = Fp*d2, where d1 is the moment arm of F1, and d2 is
the moment arm of Fp.
3. The attempt at a solution
Fp = (F1*d1)/d2
(904)(9.81)/(pi)(0.003955)^2= F/(pi)(0.00655)^2
F=242.98 N which was incorrect.
anyone have an idea of what I should do and what equation to use? Thanks!
Phys.Org News Partner Science news on Phys.org
Internet co-creator Cerf debunks 'myth' that US runs it
Astronomical forensics uncover planetary disks in Hubble archive
Solar-powered two-seat Sunseeker airplane has progress report
Redbelly98
Redbelly98 is offline
#2
Aug17-09, 07:32 PM
Mentor
Redbelly98's Avatar
P: 11,990
I think we'll need to see the figure before we can help you out.
jumpingjack90
#3
Aug17-09, 09:32 PM
P: 14
http://img6.imageshack.us/img6/7849/...56447261f7.gif
this is the link for the picture.
djeitnstine
djeitnstine is offline
#4
Aug17-09, 10:20 PM
PF Gold
djeitnstine's Avatar
P: 619
Neglecting the height difference means the pressure should be the same, thus [tex]F_1 A_1 = F_2 A_2 [/tex]
This is would be the force exerted on the small piston.
You should know how to find the force needed by the hand from this.
Redbelly98
#5
Aug17-09, 11:33 PM
Mentor
Redbelly98's Avatar
P: 11,990
Quote Quote by jumpingjack90 View Post
Fp = (F1*d1)/d2
You have correctly found F1, the force on the smaller piston. However, they are asking for Fp (labelled simply F in the figure), the force exerted by the hand.
You have the equation to find Fp given F1.
jumpingjack90
#6
Aug18-09, 01:38 PM
P: 14
ok. I used the equation given and solved for Fp. I had (242.98)(pi*(0.03955)^2))/(pi)*(0.00655)^2=Fp=8858.92 N, which is also incorrect.
what am I doing wrong?
jumpingjack90
#7
Aug18-09, 03:23 PM
P: 14
nvm. I solved it! thanks everyone for your input!
george88b
george88b is offline
#8
Mar1-11, 07:37 PM
P: 8
how u solved it my friend?
Register to reply
Related Discussions
Looking for a Bottle Jack for a Hydraulic Car Jack Mechanical Engineering 27
Help me for calculate a Hydraulic force Mechanical Engineering 3
quick hydraulic jack question Introductory Physics Homework 3
Hydraulic Car jack Mechanical Engineering 5
building a hydraulic car jack Engineering, Comp Sci, & Technology Homework 0
