Finding Final Velocity of a Block Sliding Down a Ramp with Friction
The problem involves a block sliding down a ramp with friction, specifically focusing on calculating the final velocity of the block. The scenario includes a block of mass 10 kg, a ramp length of 5 m, and a coefficient of friction of 0.4, with the ramp inclined at an angle of 30 degrees.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting up equations for net forces in both x and y directions, with some questioning the accuracy of the calculated acceleration and final velocity. There are attempts to resolve forces acting on the block, including gravitational and frictional forces, and to clarify the setup of coordinate axes.
Some participants have provided insights into the setup of the equations and the forces involved, suggesting that the original poster may need to reconsider their calculations. There is an ongoing exploration of how to correctly account for the forces acting on the block and the implications of the mass in the calculations.
Participants note that the mass of the block may not be necessary for the calculations, and there is a focus on ensuring the correct interpretation of forces in relation to the ramp's angle and the friction involved.
akatsafa
A 10 kg block slides from rest down a 5m long ramp. If the coefficient of friction between the block and the ramp is 0.4, what is the final velocity of the block when it reaches the botton of the ramp?
I set this into two Fnet equations, x and y. I then solved for the acceleration in x which i got to be -3.92 m/s^2. However, I'm not getting the correct value for the final velocity. I'm getting 6.3 m/s, but it should be 3.9 m/s. Can you please tell me what I'm doing wrong?
The angle at the bottom of the ramp is 30 degrees.
For one thing, your acceleration down the ramp is incorrect. Start by showing those equations for Fnet and how you solved them.
I have fnetx=ma=-uN...I have fnety=0=N-W..I then tried solving for acceleration...that's how I got -3.92.
Make sure you set up your axes such that the x-axis is the same as surface of the ramp and the y-axis perpendicular to it. This way it is much easier, you only have to break Fg into it's components. I'm not quite sure what you've set up for the net force in the x and y direction, however i notice that in the net force for the x direction you do not have gravity included. Here is what they should be however:
Fnetx = ma = Fgx - Fk(uFn) (force of gravity in the x direction - force of kinetic friction)
Fnety = ma = Fn - fgy (Normal force - Force of gravity in the y direction)
Also, I am not sure why you are given mass.. as you don't need it.
Angle of 30 degrees, U = 0.4, mass = 10kg, distance = 5m.
Resolving parallel force: 10GSin30 = 49N
Resolving opposite to plane, force: R - 10Gcos30 = 0, R = 84.87N
F = UR, F = .4x84.87 = 34N
49 - 34 = 10A
A = 1.5m/s/s.
u = 0, v = ?, s = 5, a = 1.5
v^2 = u^2 + 2as
?^2 = 2x5x1.5
V = 3.873 m/s.
Assuming "x" means "parallel to the ramp" and "y" means "normal to the ramp", the forces in the x direction are the x-component of the weight (mg sin(30)) and the frictional force. So:
[tex]\sum F_x = -mg sin(30) + \mu N = ma[/tex]
And the forces in the y direction are the y-component of the weight (mg cos(30)) and the normal force. So:
[tex]\sum F_y = -mg cos(30) + N = 0[/tex]
Solve for N, then for a. As has been pointed out, the mass drops out and is not needed.
  • · Replies 32 ·
  • · Replies 20 ·
