Entropy: steam engines and fridges
  • Context: Undergrad
  • Thread starter Thread starter JanClaesen
    Engines Entropy Steam
The discussion revolves around the concepts of entropy in the context of steam engines and refrigerators, exploring the relationship between heat, work, and the second law of thermodynamics. Participants examine how energy transformations affect entropy and the implications for energy conservation in thermodynamic systems.
  • One participant questions why entropy increases when a steam engine produces 10 units of warmth, converting only 8 into work, suggesting a misunderstanding of how chaos and energy relate to entropy.
  • Another participant introduces the concept of thermodynamic probability, indicating that the 8 units of work have a higher probability state than the 2 units that are not converted.
  • It is noted that the surroundings must be considered when evaluating the entropy change, as the 2 units of heat lost may contribute to increasing the entropy of the surroundings.
  • A participant explains that not all energy values can be directly compared in terms of chaos, emphasizing that energy added to a low-temperature reservoir results in a larger increase in entropy than the same energy added to a high-temperature reservoir.
  • Clarification is provided that an increase in entropy reflects the spreading of warmth rather than a total increase in warmth itself.
  • Participants discuss the distinction between energy and entropy, asserting that while both increase with temperature, they cannot be equated in terms of changes.
Participants express differing views on the relationship between energy, entropy, and temperature. While some points of clarification are made, there is no consensus on the interpretations of entropy changes in the context of steam engines and refrigerators.
Some participants highlight the importance of considering the system and surroundings in thermodynamic discussions, as well as the role of temperature in determining entropy changes. There are unresolved aspects regarding the definitions and relationships between energy and entropy.
JanClaesen
A steam engine stove produces, say, 10 units of warmth, the second law states that not all warmth can be converted into work, so 8 units are converted into orderly energy, work, and 2 units aren't converted. Why did the entropy increase, since 10 units of warmth is more chaotic than 2?
A fridge cools something down, this cooling down, or decrease in entropy, is overcompensated by producing more warmth in the back of the fridge, so how is the total energy conserved, where does this 'extra' warmth come from?
Thanks!
Science news on Phys.org
For the whole stove-work system, that "8 units" got higher thermodynamic probability.
Extra warmth comes from electricity.
Thermodynamic probability?
For the steam engine, you need to consider the surroundings as well. Though 10 units of heat is more chaotic than 2, we are only considering the system at this point. Also, it is not just the heat that determines the entropy change but the change in temperatures of the system and surroundings. The 2 units of heat that weren't converted went into heating up the gears of the turbine through friction and/or was lost due to conduction to the surroundings. The energy became more irreversibly spread out. Because of that, the entropy increased.
Thanks!
10 units of warmth are not necessarily more chaotic than 2; in fact, you can't compare two energy values and say that one has higher entropy. If I have two reservoirs, one at high temperature [itex]T_H[/itex] and one at low temperature [itex]T_L[/itex], the same amount of energy (measured in Joules) will cause a larger increase in entropy (measured in Joules per Kelvin) when added to the low-temperature reservoir compared to the high-temperature reservoir.
And that's the whole idea of a heat engine: you produce 10 units of thermal energy, turn 8 into work, and send 2 as thermal energy to your low-temperature reservoir. Simultaneously, you produce [itex]10/T_H[/itex] units of entropy, turn none into work (because work carries no entropy) and output at least [itex]2/T_L[/itex] units of entropy to the low-temperature reservoir. [itex]10/T_H[/itex] and [itex]2/T_L[/itex] are the same number. So energy is conserved, and entropy is conserved (for a reversible engine) or increases (for a real engine).
Your other question can also be resolved by distinguishing energy and entropy. They are most definitely not the same thing.
Thanks, that was really clarifying :smile:
An increase in entropy is actually warmth being more spread, not necessarily a total increase in warmth?
Entropy increases with temperature, and energy increases with temperature, but you can't equate the two and argue that equal energy changes correspond to equal entropy changes.
  • · Replies 26 ·
  • · Replies 26 ·
  • · Replies 17 ·
