Register to reply
Compute the volume charge density of a charged spherical conductor
by Count Iblis
Tags: charge, charged, compute, conductor, density, spherical, volume
Share this thread:
Count Iblis
#1
Aug21-09, 03:54 PM
P: 2,157
In this problem we assume that the photon mass is m > 0. We take a conducting sphere of radius R and put a charge of Q on it. Some fraction of the charge will then reside at the surface and a fraction will move into the bulk. Evaluate the volume charge density in the bulk.
I was shocked to learn in another thread that some people believe that the fact that there are no charges inside a conductor has nothing to do with Coulomb's law (apart from the mere fact that it leads to a repulsion between like charges). So, I invented this problem, solved it, and because it turned out to be quite easy, posted it here.
B.t.w., what is even easier is to simply see that not all of the charge can reside at the surface.
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
Gear300
#2
Aug21-09, 08:18 PM
P: 1,133
I forgot a bit of electrodynamics, so I'll ask:
For a conductor, any charge applied to it can by uniformly distributed across the volume of the conductor, right?
Count Iblis
#3
Aug26-09, 10:52 AM
P: 2,157
Quote Quote by Gear300 View Post
It will stay on the surface, unless Coulomb's law is invalid.
Count Iblis
#4
Aug26-09, 10:54 AM
P: 2,157
If no one solves the problem by Monday, I'll write up the answer then.
belliott4488
#5
Aug26-09, 11:02 AM
belliott4488's Avatar
P: 666
Are you assuming idealized point-like charge carriers and a perfect conductor, etc.? If so, then doesn't Gauss's Law ensure that the charges will all accumulate a the surface? I'm just imagining a spherical Gaussian surface concentric with the conducting sphere and with a radius less than but arbitrarily close to the radius of the conductor.
Count Iblis
#6
Aug26-09, 11:18 AM
P: 2,157
Quote Quote by belliott4488 View Post
Yes, that is correct. So, if Coulomb's law is valid, then we can derive that Gauss' law is valid and then you find this result. The question is what happens if Coulomb's law is not valid. You can e.g. consider the case of a massive photon and explicitely work out the case of a charged sphere. You then need to consider how the Maxwell equations (particularly Gauss' law) changes. The case of the massive photon is simpler than any other changes of Coulomb's law.
Count Iblis
#7
Aug30-09, 08:56 AM
P: 2,157
Deadline is 30 hours from now. An F minus grade will be awarded to PF if there is no response by then.
Gear300
#8
Aug30-09, 01:00 PM
P: 1,133
Quote Quote by Count Iblis View Post
Do you mean proton? And since you mentioned mass, are you trying to involve gravity into the equations?
Vanadium 50
#9
Aug30-09, 01:33 PM
Mentor
Vanadium 50's Avatar
P: 16,385
No, he means photon. This is leftover from another thread.
What I suspect is going to happen is that Count Iblis will note that [itex]\nabla \cdot E = -\rho/\epsilon_0 - m^2 \phi [/itex], and then argue that with a surface charge the field isn't zero because of the [itex]m^2 \phi [/itex]. There will then be a long drawn-out discussion about what a conductor is: is it a material where the electric field is zero everywhere, or is it a material where charges are free to move? In Maxwell electrodynamics, the two are the same. In Proca electrodynamics, they are not.
Gear300
#10
Aug30-09, 04:04 PM
P: 1,133
Quote Quote by Vanadium 50 View Post
What I suspect is going to happen is that Count Iblis will note that [itex]\nabla \cdot E = -\rho/\epsilon_0 - m^2 \phi [/itex], and then argue that with a surface charge the field isn't zero because of the [/itex]m^2 \phi [/itex]. There will then be a long drawn-out discussion about what a conductor is: is it a material where the electric field is zero everywhere, or is it a material where charges are free to move? In Maxwell electrodynamics, the two are the same. In Proca electrodynamics, they are not.
What is Proca electrodynamics?
Count Iblis
#11
Aug30-09, 04:06 PM
P: 2,157
A conductor is an object in which charges are free to move and that implies (also in Proca theory) that the electric field is zero in the interior of the conductor.
Gear300
#12
Aug30-09, 04:51 PM
P: 1,133
Where do photons come into play?
Phrak
#13
Aug30-09, 06:08 PM
P: 4,512
I can't say that the assuptions of your set-up are clear. There can be electric fields within a conductor--or is this about electrostatics, only? If so, why the massive photon?
Count Iblis
#14
Aug30-09, 06:24 PM
P: 2,157
Quote Quote by Phrak View Post
This is about electrostatics. To answer also Gear's question, The massive photon causes the Coulomb potential of a point charge q to be modified. It becomes the Yukawa potential:
V(r) = q/(4 pi epsilon_0) exp(-m c/hbar r)/r
Gear300
#15
Aug30-09, 10:08 PM
P: 1,133
Looks like there is more involved with this problem than I thought there was.
Count Iblis
#16
Aug31-09, 10:49 AM
P: 2,157
It is in fact pretty easy to solve. You can e.g. simply start with the Yukawa potential and derive from that how to generalize Gauss' law and proceed from that.
Count Iblis
#17
Sep2-09, 11:22 AM
P: 2,157
Answer:
[tex]\rho = \frac{Q}{4\pi R \lambda^{2}}\frac{1}{1+\frac{R}{\lambda}+\frac{R^2}{3\lambda^2}}[/tex]
where
[tex]\lambda=\frac{\hbar}{mc}[/tex]
is the photon Compton wavelength
Count Iblis
#18
Sep19-09, 09:58 PM
P: 2,157
Sadly, I have had to award PF an F-minus grade, for not having submitted any work
Register to reply
Related Discussions
Point charge at the center of a spherical conductor Introductory Physics Homework 17
Electric potential: point charge in a hollow charged conductor Introductory Physics Homework 4
Amount of charge spherical conductor can hold in air General Physics 1
How can a conductor of uniform charge density exist Classical Physics 7
Volume Charge Density Introductory Physics Homework 1
