| Thread Closed |
Amplitude of a photon |
Share Thread | Thread Tools |
| Aug22-09, 09:08 AM | #1 |
What's the formula for the amplitude of a photon?
Thanks. |
| Aug22-09, 10:36 AM | #2 |
Mentor
What do you mean by the "amplitude of a photon?"
| Aug22-09, 12:31 PM | #3 |
| Aug24-09, 04:37 AM | #4 |
Amplitude of a photonI mean the amplitude of probability that has a photon in A at T1 to appear in B at T2. Bob_for_short:could you explane me this formula please?(I'm just an incoming freshman) Thanks a lot. |
| Aug25-09, 05:52 AM | #5 |
Besides, I read that the probability for a photon in A(x_A,y_A,z_A) at t=T1 to be found in B(x_B,y_B,z_B) at t=T2 was given by a simple formula in which appear (x_A-x_B)^2, (y_A-y_B)^2,(z_A-z_B)^2 and (T1-T2)^2. If anyone has a clue...
| Aug25-09, 06:48 AM | #6 |
Mentor
This is what happens when you neglect to provide a clear and complete context to your question.
Zz. |
| Aug26-09, 04:05 AM | #7 |
Then I should provide a clear context to my question:
By “amplitude of a photon”, I mean the amplitude of probability for a photon situated in a point A of the space A(xA,yA,zA) at t=T1 to appear in an other point B(xB,yB,zB) at t=T2. Indeed, I read (QED: The strange theory of light and matter) that we could not consider that a photon travelled in a straight line and therefore, we must consider all the potential ways the photon could take. Besides, a photon has also amplitudes to travel faster or lower than the speed c. These amplitudes reduce each other to zero in long distances, but they must be taken in consideration for short distances. I guess this problem is in relation with path integrals, but I also read that the amplitude of a photon had a simple expression that depends on (xA-xB)^2, (yA-yB)^2,(zA-zB)^2 and (T1-T2)^2: I’m looking for this expression. Thanks for your help. |
| Aug26-09, 04:15 AM | #8 |
| Aug30-09, 09:44 AM | #9 |
Assuming thhe journey of the photon from A to B is one-step, and nothing else is involved in the system, then the probability can be described by:
P(A to B) and is calculated from the inverse of the difference in the squares between the change in position and the change in time (interval) The simplification is due to consideration of a photon, becasue photons travel at the speed of light, (B-A) EQUALS (T2 - T1) There are probabilities where the speed of the photon does not equal c, but these cancel out accordingly, so the formula is simplified by not having to include the excess of the time difference. As you already quoted the cartesian geometrical calculation of the position of A and B, you pretty much had the simplified equation: ( (( (BX - AX)^2 ) + ( (BY - AY)^2 ) + ( (BZ - AZ)^2 ) ) ^ (1/2) ) I don't think it gets any simpler than this, unless perhaps the photon only moves in one dimension? ((BX - AX)^2)^1/2) Also, this is not including any polarisation. |
| Aug30-09, 12:01 PM | #10 |
Richard Feynman in some of his books likes to use the term "amplitude". (see his "Lectures on Physics" volume III). If you want to calculate the probability a particle known to be in a certain state to be found in a different state , you take the dot product (inner product) of both state vectors. The expressions you list at the end are part of the expression for the "interval" in special relativity. (xA-xB)^2+ (yA-yB)^2+(zA-zB)^2 - (T1-T2)^2 does not vary when you look at the events from reference frames moving at different velocities. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Amplitude of a photon
| Photon and amplitude | High Energy, Nuclear, Particle Physics | 2 | ||
| atomic photon versus cavity photon | Quantum Physics | 4 | ||
| Amplitude of a photon? | General Physics | 1 | ||
| [SOLVED] Photon Power [was Re: Intensity of a Photon] | General Physics | 2 | ||
