Register to reply
Simple harmonic motion
by Eric_meyers
Tags: harmonic, motion, simple
Share this thread:
Eric_meyers
#1
Aug23-09, 10:20 AM
P: 68
"Two light springs have spring constants k1 and k2, respectively, and are used
in a vertical orientation to support an object of mass m. Show that the angular
frequency of small amplitude oscillations about the equilibrium state is
[(k1 + k2)/m]^1/2 if the springs are in parallel, and [k1 k2/(k1 + k2)m]^1/2 if
the springs are in series. "
2. Relevant equations
f = -kx
w = (k/m)^1/2
frequency = w/(2 * pi)
3. The attempt at a solution
So I set up my fnet for the parallel one
m * x'' = - (k1x + k2x) since in the parallel feature there are two distinct springs exerting two distinct forces
however dividing through I'm left with
x'' = - (k1x + k2x)/m
I'm not quite sure how to use x'' to get to angular frequency or how to remove the negative sign.
Phys.Org News Partner Science news on Phys.org
Law changed to allow 'unlocking' cellphones
Microsoft sues Samsung alleging contract breach
Best evidence yet for coronal heating theory detected by NASA sounding rocket
Fightfish
#2
Aug23-09, 10:24 AM
P: 623
For a simple harmonic oscillation, x"=-(w^2)x
Feldoh
#3
Aug23-09, 10:29 AM
P: 1,345
Solutions to x'' = -[(k1+k2)/m]x can be written in the form x(t) = A*sin(wt+phi) so from what you know about the sine function if you can find the period, you can find the frequency, which will enable you to find the angular frequency...
Eric_meyers
#4
Aug23-09, 12:09 PM
P: 68
Oh I think I got it!
x'' + [(k1 + k2)/m]x = 0
And using the characteristic polynomial to solve this second order DE, gives me the solution
x(t) = A cos(wt + phi) if and only if w = [(k1 + k2)/m]^1/2
now for setting up the DE in the series case I'm having some difficulty would it be:
m * x'' = -k1 * k2 x ? Since you could treat both k1 and k2 acting as one k? errr..
Fightfish
#5
Aug23-09, 12:16 PM
P: 623
Quote Quote by Eric_meyers View Post
Sure you got the effective k for springs in series correct?
Eric_meyers
#6
Aug23-09, 01:16 PM
P: 68
oh wait, if I want to combine the k in both springs into another constant I'm going to have to take the "center of mass" sort of speak for the spring stiffness - I forget the correct terminology... center of stiffness?
m * x'' = -[(k1 * k2)/(k1 + k2)] x
x '' + (k1 * k2)/[(k1 + k2) * m]x = 0
Using the characteristic equation I again get
x(t) = A cos (wt - phi) if and only if w = {(k1 * k2)/[(k1 + k2) * m]}^1/2
Which of course is the answer.
Thanks
Register to reply
Related Discussions
A simple question on simple harmonic motion Introductory Physics Homework 14
Simple Harmonic Motion- From Uniform Circular Motion Introductory Physics Homework 5
Motion of object (simple harmonic motion?) Introductory Physics Homework 3
Simple Harmonic Motion and Wave Motion General Physics 2
Simple Harmonic Motion/Wave Motion Introductory Physics Homework 2
