Integral Meaning: Work & Impulse
  • Context: Undergrad
  • Thread starter Thread starter JanClaesen
    Impulse Work
The discussion revolves around the concepts of work and impulse in physics, specifically examining the relationship between integrals, derivatives, kinetic energy, and momentum. Participants explore whether integrals can be interpreted as measures of change and how these concepts relate to physical quantities.
  • Some participants propose that work is the integral of force over distance and impulse is the integral of force over time, suggesting a general understanding of integrals as measures of change.
  • Others argue that while kinetic energy and momentum have similar formulas, they represent different physical concepts, with momentum being a vector and kinetic energy a scalar.
  • A participant emphasizes the importance of recognizing that momentum is defined as a vector quantity, while kinetic energy is derived from work, which involves path integrals of force.
  • One participant challenges the notion that an integral represents how much something has changed, providing examples where integrals yield non-zero values without corresponding changes in physical quantities.
  • Another participant reflects on the interpretation of integrals and derivatives in physics, suggesting that understanding the mathematical structure is crucial for applying these concepts to physical magnitudes.
Participants express differing views on the interpretation of integrals and their relation to physical change, with no consensus reached on whether integrals can be seen as measures of change in all contexts.
Some limitations include the dependence on definitions of physical quantities and the unresolved nature of how integrals relate to changes in specific contexts, such as constant functions.
JanClaesen
Work is the integral of force over a certain distance, impulse the integral of a force over a certain time span. A derivative tells us how fast something is changing at a certain point, an integral tells us how much something has changed up until that point, is this generally true (an integral is how much something has changed), or is there a better view to visualise the meaning of integration?
Kinetic energy and momentum have very similar formulas, though kinetic energy is the integral of the resulting force with respect to distance, and momentum with respect to time, is it wrong to visualise momentum the same way as kinetic energy?
I'm not sure how to answer this question...but for the case, in which you're trying to relate kinetic energy and momentum, it is reasonable to say that both describe an object's motion, though you should note that momentum describes an inertial property of an object in motion as a vector; kinetic energy is a scalar description of an object in motion.
They do look similar at the begening but you have to take into account a very important fact that, i guess, you've misregarded. This is that momentum is a vector and energy is not. The kinetic energy formulae comes from the one of work (the path integral of a force over a trajectory trough the space) and the Work-Kinetic Energy theoreme which equals one to each other (mathematically demonstrable). Momentum, though, is a magnitude difined as p=mv where v is vectorial and so p is. 2nd Newton law claims that F=dp/dt (both p and F vectors) and there you have the integral for a certain variation of p between instants t1 and t2, knowing F(t).
Concernig to the interpretation of integrals and derivatives in "real" physics, I'd just say that you should get to understant the mathematical structure of the classical physics (in this case) and then realize that as long as a measurable magnitude is treated as a real valuated function, assuming all the algebra behind them, all operators (derivatives, integrals...) and theoremes (calculus main theorem...) they "use" may have their application to the physics magnitudes.
Hope this helps, please reply any question you have about my explanation or whatever JanClaesen.
An integral isn't how much something has changed, though. For example, the integral of a constant is the constant times the interval of integration, which is non-zero (for a non-zero constant), even though nothing changed. A good example is the integral of constant velocity, which is a simple displacement, not change in velocity or something along those lines.
I don't know, I can't think of any good description off the top of my head that has physical significant comparable to the definition you gave for the derivative.
Thanks, that was clarifying :smile:
Ah indeed, the constant function, the integral value over a certain x-period is relative? So if F(2) - F(1) > F(3) - F(2) 'more' has changed in the interval 1 -> 2, 'what' has changed depends on what the x and y value represent, in the case of distance and force we call it work.
So: the work done by a force from a point x1 to x2 equals the difference in energy of the system: the system has more possibility to do work.
The impulse of a force from t1 to t2 equals the difference in momentum of the system.
  • · Replies 35 ·
  • · Replies 27 ·
  • · Replies 138 ·
9K
  • · Replies 60 ·
  • · Replies 31 ·
