Why Does Yahoo Messenger Sign Me Out When Checking Email?
  • Thread starter Thread starter EngWiPy
The discussion revolves around the issue of being signed out of Yahoo Messenger when accessing Yahoo email. Participants explore potential reasons for this behavior, including concerns about account security and technical functionalities of the Yahoo interface.
  • Technical explanation, Debate/contested
  • One participant expresses concern that being signed out could indicate account compromise.
  • Another participant suggests that the sign-out could occur if a different computer is used or if auto-login is enabled.
  • Some participants note that forgetting to log out before signing in again could lead to this issue.
  • One participant mentions that Yahoo's email interface has a limited IM applet that causes automatic sign-out when checking email.
  • Another participant agrees with the observation that signing out occurs specifically when checking Yahoo email.
  • A suggestion is made that changing the password may be a prudent step if the issue persists.
Participants do not reach a consensus on the exact cause of the sign-out issue, with multiple competing views presented regarding potential reasons and implications.
Some assumptions about user behavior, such as auto-login settings and the use of multiple devices, are not fully explored. The discussion does not clarify the technical workings of the Yahoo Messenger and email integration.
EngWiPy
Hello,
I always encounter with the following message that I have been signed out from yahoo messenger because I signed in in different computer. What this message means? Does this mean that my account has been compromised?
Regards
Computer science news on Phys.org
S_David said:
Hello,
Regards
It could mean that, yes. It could also mean somebody turned on another computer you use to access yahoo chat (if you have it set to auto-login).
I get that if I forget to log out before logging in again.
Negative, none of them happen.
Hi David.
I got the same problem while checking my e-mail, Y!'s mail interface (both the old & the new one) has some sort of limited IM applet that'll pop you out when you check your mail.
If that's not the case, the safest way is to change your password.
ketamynx said:
Hi David.
Yes this is the case, I noticed that. Just when I check my yahoo email, I signed out automatically from the messenger.
Regards
