Thomas Young's Double Slit Experiment
The discussion centers around recreating Thomas Young's Double Slit Experiment, focusing on the use of laser pointers for observing and photographing interference patterns. Participants explore the suitability of different laser power levels and techniques for capturing clear images of the interference fringes.
  • Homework-related
  • One participant inquires whether a 5 mW laser pointer is sufficient for the experiment and considers purchasing a 100 mW laser pointer as an alternative.
  • Another participant suggests that even a low power 1 mW red laser pointer can produce visible fringes, advising against using a 100 mW laser from eBay.
  • It is noted that conducting the experiment in a dark room can enhance the visibility of the fringes.
  • A participant mentions their plan to project the fringes onto a whiteboard and photograph them, expressing confidence based on previous experiences with camera phones.
  • Concerns are raised about potential issues with digital cameras, such as focusing problems or software interference that might affect the visibility of the fringes.
  • A participant shares a video demonstrating the use of a cheap laser pointer to achieve the double slit effect, suggesting that similar materials could be used to create a more permanent double slit screen.
Participants generally agree that lower power lasers can be effective for the experiment, but there are differing opinions on the necessity and safety of using higher power lasers. The discussion remains unresolved regarding the best practices for capturing clear images with digital cameras.
Participants express varying assumptions about the capabilities of different cameras and the conditions under which the interference patterns can be effectively observed and photographed.
Cmertin
I have to recreate Thomas Young's Double slit experiment and take pictures of the interference patters for a research paper. My teacher has a powerful red laser at school that I can use, though i know that the interference pattern changes with the changing frequencies. I was wondering if a 5 mw laser pointer would be powerful enough for this experiment. If it is not powerful enough, what would be the best to get. There is a 100mw laser pointer on ebay that I could buy, though it is $60 and I don't want to spend that much if I don't have to.
Any help will be appreciated
Thanks,
Cmertin
You can easily see fringes with even a low power 1mW red laser pointer.
You really DO NOT want to play with 100mW laser from ebay.
To see the fringes more clearly just do it in a darker room.
If you are taking pictures of the fringes by projecting them onto film there is no limit to how low power you can use. If you are planing to photograph them indirectly with a digital camera it might be trickier
Thanks.
I plan on doing this in a dark room, and projecting the fringes on a whiteboard and then taking a picture of them and then including them in the lab. We've done this lab before and were able to get pretty clear pictures with our camera phones, so I don't see why an actual camera wouldn't be able to get a clear picture.
If you can see a projected image on a screen (ie whiteboard) you should be able to photograph it with a digital camera.
A lot of textbooks describe experiments with film, such as having a light source that only emits a few photons/second and using an hour long exposure on film to show there are still fringes - which wouldn't work with a digital camera.
You can also have problems if the digital camera can't focus or the optical effect you are trying to see is removed by the camera's software because it isn't somethign the designers expected in a normal family photo.
Oh, ok, thanks for all your help. =p
Here's a video of someone using a cheap laser pointer to get the double slit effect. He used pencil lead to block the photons. It would be easy to use similar materials to make a more permanent double slit screen.
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 32 ·
  • · Replies 26 ·
