Register to reply
Vectors Linear Independent
by CSNabeel
Tags: independent, linear, vectors
Share this thread:
CSNabeel
#1
Aug25-09, 11:21 AM
P: 12
Considering the following vectors R[tex]^{4}[/tex]:
v1 = (1,2,0,2) v2 = (2,3,1,4) v3 = (0,1,-1,0)
Determine if these vectors are linearly independent. Let S be the linear span of the three vectors. Define a basis and the dimensions of S. Express the vector v=(3,5,1,6) as a linear combination of the three vectors. Can this be achieved in a unique way? Justify your answer?
2. Relevant equations
I tried to put it into matrix form and reduce via row echolon but I'm not if this is the correct or proper way
3. The attempt at a solution
[ 1 2 0 2
2 3 1 4
0 1 -1 0
3 5 1 6]
[ 1 2 0 2
0 -1 1 0
0 1 -1 0
0 0 0 0 ]
x +2y = 2
y - z = 0
-y + 2 = 0
therefore
y=z making it linearly independent
Phys.Org News Partner Science news on Phys.org
Pilot sites in energy from coffee waste show good results
Startups offer banking for smartphone users
Factor in naked mole rat's cells enhances protein integrity
Дьявол
#2
Aug25-09, 11:51 AM
P: 365
You need to prove that p=q=r=0, for v1,v2,v3 to be linear independent:
[tex]pv_1 + qv_2 +rv_3=0[/tex]
[tex]p(1,2,0,2)+q(2,3,1,4)+r(0,1,-1,0)=0[/tex]
You should express the vector v in same manner as linear combination of v1,v2,v3: i.e pv1+qv2+rv3=v
p,q,r are random scalars.
Regards.
CSNabeel
#3
Aug25-09, 12:02 PM
P: 12
so with that being said which of the two do I follow from below to work out the answer?
a)
1p + 2q = 0
2p +3q +r = 0
q - r = 0
2p + 4q = 0
b)
1p + 2q = 3
2p +3q +r = 5
q - r = 1
2p + 4q = 6
and if I follow b I'm I right to think that p = 1 q =2 and r = 0
Дьявол
#4
Aug25-09, 12:23 PM
P: 365
Quote Quote by CSNabeel View Post
a)
1p + 2q = 0
2p +3q +r = 0
q - r = 0
2p + 4q = 0
b)
1p + 2q = 3
2p +3q +r = 5
q - r = 1
2p + 4q = 6
Ok, your task have two parts,
a) to check the linear independence of the vectors v1,v2 and v3
b)to find out if the vector v can be represented as linear combination of the vectors v1,v2 and v3.
So you need to solve both a) and b).
Regards.
CSNabeel
#5
Aug25-09, 12:36 PM
P: 12
a)
1p + 2q = 0 (1)
2p +3q +r = 0 (2)
q - r = 0 (3)
2p + 4q = 0 (4)
(3) q = r
(1) p = -2q
put (3)and(1) into (2) 2(-2q) + 3(q) +q = -4q +3q + q = 0
p=-2
q = 1
r = 1
vectors are dependent
b)
1p + 2q = 3 (1)
2p +3q +r = 5 (2)
q - r = 1 (3)
2p + 4q = 6 (4)
(3) q - 1 = r
(3) into (1) 2p + 3q + (q-1) = 5 ; 2p +4q = 6 (same as 4)
(4) can be divide by 2 to equal (1) answer therefore is
p = 1
q = 1
r = 0
so it that then correct?
Thank you by the way your really helpful
Дьявол
#6
Aug25-09, 12:56 PM
P: 365
I am glad that I helped you.
Just a little correction:
a)
r=q
p=-2q
q any number in R, you chose q=1
The vectors are linear dependent
b)
r=q-1
p=3-2q
q any number in R, you chose it q=1
Regards.
Register to reply
Related Discussions
Linear Algebra (Vector spaces, linear independent subsets, transformations) Calculus & Beyond Homework 12
Linearly Independent Vectors Calculus & Beyond Homework 14
Linearly independent vectors Calculus & Beyond Homework 26
Linear Algerba - Finding linearly independent vectors Linear & Abstract Algebra 5
PROOF: Independent vectors and spanning vectors Linear & Abstract Algebra 8
