Calculate Rotational Velocity of Object Around Fixed Point
The discussion focuses on calculating the rotational velocity of an object around a fixed point, specifically using the example of a clock hand. It is established that the rotational velocity (v) increases proportionally with the radius (r), defined by the formula [nu] = v/r, where [nu] represents angular velocity in radians per second. The relationship between arc length (a) and angular displacement ([alpha]) is also clarified, with [alpha] = a/r. This means that while the velocity varies along the length of the hand, the angular velocity remains constant across all points.
  • Understanding of rotational motion concepts
  • Familiarity with angular velocity and its units
  • Basic knowledge of trigonometry and radians
  • Ability to apply mathematical formulas in physics
  • Study the relationship between linear and angular velocity in physics
  • Explore the concept of centripetal acceleration in rotational systems
  • Learn about the applications of angular velocity in engineering
  • Investigate the mathematical integration of angular displacement over time
Students of physics, engineers working with rotational systems, and anyone interested in understanding the dynamics of objects in circular motion.
einsteinian77
How could i calculate the velocity of an object rotated around a fixed point such as a hand on a clock. It seems as though each section of the hand would have a different velocity, the end part being the fastest while the beginning part being the slowest if not moving at all. I am guessing the velocity would be expressed in frequency somehow.
Originally posted by einsteinian77
Im guessing the velocity would be expressed in frequency somehow.
That's correct, einsteinian77. Since the rotational velocity v increases proportional with radius r (distance from center), you define the angular velocity
[nu] = v/r.
This is the same for all points. The unit is 1/s. You could also say it's radians per second, since by integrating you get the angle:
[alpha] = a/r
where a is the arc length, and [alpha] is measured in radians.
  • · Replies 47 ·
  • · Replies 60 ·
  • · Replies 21 ·
