| Thread Closed |
Thin, light, cheap and strong as wood material? |
Share Thread | Thread Tools |
| Aug28-09, 11:28 PM | #1 |
Hi,
I am currently constructing a science fair project, and I was wondering if anybody knew any thin material that was relatively light weight, cheap, and as strong as wood. I understand that carbon fiber exists, but this material is rather expensive. If anyone knows alternatives to using wood or carbon fiber, please inform me. Thanks. |
| Aug29-09, 07:55 AM | #2 |
Why can't you use wood? Fibre glass might work depending upon the application.
| Aug29-09, 09:15 AM | #3 |
Aluminum. You can buy it in thin sheets at your local hardware store, or even at some hobby stores.
You should share with us the intended application. The material chosen will depend on this. For example, sheet aluminum is light and string but will bend. |
| Aug29-09, 09:51 AM | #4 |
Its intended application is for a shaft, approxamately 1.5" wide, but I only need less than .5" of the material. It is intended to be wraped around the shaft. Sorry I cannot give away more, because I still want to keep my science fair idea rather confidential.
Thanks. |
| Aug29-09, 10:43 AM | #5 |
So you're not talking about the shaft itself, but merely a material to bind it?
If it's the shaft, bamboo is straight, cheap, and even stronger than carbon fibre. I don't know whether or not that counts as wood, though. For wrapping, you can get fibreglass packing tape at any hardware store. The lifespan is limited, since it crystalizes after a few years. If you're a Red Green fan, never forget the "handyman's secret weapon"...
| Aug29-09, 06:11 PM | #6 |
The shaft is 1.5" in diameter, OK. Do you already have the shaft? And you are looking for a material to wrap around the shaft? That needs to be some pretty flexible material! How would you do that with wood?? .5" of wood would never wrap around a shaft. Or are you maknig the shaft out of this material? And the wall of the shaft need be only .5" thick? I?f so, what is it that is getting wrapped around the shaft? |
| Aug30-09, 02:09 PM | #7 |
Alright, I see how those statements can appear contradictory, so I will explain it clearer. Lets say there is a shaft, 1" wide, and I want to wrap .5" of some material around it to reinforce it and make it stronger. Wood would not work for this project because even if I used flexible wood, it would not be able to mold itself to the shaft. So, I am looking for a material that is as strong as wood, but flexible enough to be able to be wrapped around a shaft. That is why I am currently looking at fiber glass, but I am open to more suggestions.
Hopefully this cleared it up. Thanks! |
| Aug30-09, 02:34 PM | #8 |
Mentor
Epoxy?
| Aug30-09, 03:32 PM | #9 |
What properties does the end-product need to have? How precise? At high rotational speeds, any freeform material such as fibreglass will generate vibrations.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thin, light, cheap and strong as wood material?
| Lightweight and Very Strong Material | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Determining the static and kinetic coefficients on an incline of wood on wood! | Introductory Physics Homework | 1 | ||
| RP material suggestion needed (strong plastic) | Mechanical Engineering | 5 | ||
| Cheap fun with polarized light | Quantum Physics | 4 | ||
| strong light | General Physics | 8 | ||
