Integral: Find x=sin θ for 0-0.5
The discussion revolves around evaluating the integral \(\int _0^{0.5}\frac{x}{\sqrt{1-x^2}}dx\) using the substitution \(x=\sin \theta\). Participants explore the implications of changing the upper bound of the integral and the effects of different choices of \(\theta\) on the evaluation.
  • Participants discuss the substitution method and the potential choices for the upper bound of the integral, questioning the validity of using \(\theta = \frac{5}{6}\pi\) instead of \(\theta = \frac{\pi}{6}\). There is also a focus on the implications of the absolute value in the context of the cosine function.
The discussion is active, with participants providing insights into the implications of their choices and questioning assumptions about the behavior of the cosine function in different quadrants. Some guidance has been offered regarding the absolute value and the need to consider both positive and negative cases.
Participants are navigating the complexities of trigonometric identities and the behavior of functions in different quadrants, particularly in relation to the integral's bounds and the substitution method. There is an acknowledgment of the potential for multiple interpretations of the integral based on the chosen bounds.
songoku
Find using substitution [tex]x=\sin \theta[/tex]
[tex]\int _0^{0.5}\frac{x}{\sqrt{1-x^2}}dx[/tex]
integration
[tex]=\int_0^{\frac{\pi}{6}}\sin \theta\;d\theta[/tex]
[tex]=1-\frac{1}{2}\sqrt{3}[/tex]
What I want to ask is about changing the upper bound of the integral.
For x = 0.5 :
[tex]0.5 = \sin \theta[/tex]
Here I choose [tex]\theta = \frac{\pi}{6}[/tex]. But what if I choose [tex]\theta = \frac{5}{6}\pi\;??[/tex]
So, the integral :
[tex]=\int_0^{\frac{5}{6}\pi}\sin \theta\;d\theta[/tex]
[tex]=1+\frac{1}{2}\sqrt{3}[/tex]
Thanks
A good way to check your answers on integration problems is to solve them in different ways and compare their answers. One way to do this is to use another integration method.
Be careful!
We have, ignoring boundary values:
[tex]\int\frac{xdx}{\sqrt{1-x^{2}}}=\int\frac{\sin\theta\cos\theta{d\theta}}{\sqrt{1-\sin^{2}\theta}}=\int\sin\theta\frac{\cos\theta}{|\cos\theta|}d\theta[/tex]
Do you see what you need to be careful about when simplifying this further?
In particular, why is your choice: "But what if I choose [itex]\theta=\frac{5}{6}\pi[/itex]" troublesome?
Hi arildno and espen180
In particular, why is your choice: "But what if I choose [itex]\theta=\frac{5}{6}\pi[/itex]" troublesome?[/QUOTE]
Ah, maybe you are referring to the square root. The value of [tex]\cos \theta[/tex] should be positive so the angle should be in first quadrant, where the values of sin and cos are positive.
I've checked it using substitution u = 1-x^2 and got the answer. What I am confused is about why I can't take the upper bound to be (5 pi)/6. But I think I get it now
Thank you very much, arildno and espen180 :smile:
It is same either if you pick п/6 or 5п/6 because п - п/6 = 5п/6 and both result with positive value of sin(x).
What arildno meant to say is that you should be careful with the absolute value [tex]\int{sin(x)\frac{cos(x)}{|cos(x)|}dx}=\int{sin(x)\frac{cos(x)}{\pm cos(x)}dx}=\int{\pm sin(x)dx}[/tex]
So, you should consider the negative values for cos(x) and not just the positive ones. :smile:
P.S And why you chose x=0 for sin(x)=0, why you did not choose x=п, since both are valid?
Hi njama
I don't really understand about the absolute sign. Why can it be negative? I think it's should be positive since it's a square root and we don't have to consider the negative value.
Thanks :smile:
Ok, I will explain.
For example if you have [itex]y^2=16[/itex] so that we can write |y|=4
What that means is y can be either -4 or 4 so that |y|=4 or [itex]y=\pm 4[/itex]
Lets check it out:
(-4)2=16, 42=16 or |-4|=4 but also |4|=4
In this case take cos(x) = y, and you will see what I am talking about. :smile:
songoku said:
Hi njama
Thanks :smile:
Of course, [itex]|cos(\theta)|[/itex] cannot be negative. But you can write it as [itex]\pm cos(\theta)|[/itex] because [itex]cos(\theta)[/itex] itself can be positive or negative.
IF [itex]\theta= (5/6)\pi[/itex] then [itex]cos(\theta)= cos((5/6)\pi)= -\sqrt{3}/2[/itex] so [itex]|cos(\theta)|= - cos(\theta)= \sqrt{3}/2[/itex].
Hi njama and Mr. HallsofIvy
This is my interpretation after reading your posts.
[tex]\int_{0}^{0.5}\frac{xdx}{\sqrt{1-x^{2}}}[/tex] can turn out to be:
[tex]1.\int_{0}^{\frac{\pi}{6}}\sin \theta\;d\theta\;\text{or}[/tex]
[tex]2.\int_{\pi}^{\frac{5}{6}\pi}-\sin \theta\;d\theta[/tex]
Am I right? Or maybe there are any other forms with different upper and lower bounds?
Thanks
  • · Replies 19 ·
  • · Replies 20 ·
