Which Axes Should a Coil Rotate Around to Induce EMF?
The discussion revolves around the conditions under which a coil of wire, positioned in the xy-plane with a magnetic field along the y-axis, can generate an electromotive force (emf) when rotated around different axes. Participants are exploring the implications of Faraday's Law in this context.
  • Participants discuss the effects of rotating the coil around the x, y, and z axes on the induced emf. Questions are raised about how the angle between the coil and the magnetic field changes with rotation, and whether this affects the magnetic flux through the coil.
There is an ongoing exploration of the effects of rotation on emf generation, with some participants suggesting that rotation around the x-axis would induce emf, while others argue that rotation around the y-axis would not. The discussion includes considerations of the coil's orientation relative to the magnetic field and the implications of changing magnetic flux.
Participants note that the question may belong in a homework section, indicating a structured approach to the problem. There is also mention of the need to consider the coil's thickness and the potential for eddy currents when discussing rotation around the z-axis.
uzair_ha91
http://img30.imageshack.us/img30/7309/coil.png
The figure shows a coil of wire in xy-plane with a magnetic field along y-axis. Around which of the three axis should the coil be rotated in order to generate emf and current in the coil?
I think the answer is X and Z AXES because in these cases the plane of the coil (or the coil?) is
perpendicular to the magnetic field.
Please confirm this...
First, this question should really be in the homework section.
Second, think about Faraday's Law...a changing ___?___ produces an emf...When you rotate the coil around the z-axis does the ___?___ through the coil change? How about around the y-axis? Around the x-axis?
Achanging magnetic flux produces an emf...
Well, if the ring is rotated around y-axis, the coil will definitely be parallel to the magnetic field so [tex]\epsilon[/tex]=vLBsin0=0
The opposite will happen if rotated around x-axis, [tex]\epsilon[/tex]=vLBsin90=vLB
But what if the coil is rotated around z-axis?
in an abstract view, nothing will happen if rotated about z-axis, the coil is still parallel to the magnetic field and no change in flux is made, so no current induced, however if we considered the coil's thickness there will be some eddy currents perpendicular to the flux direction.
so rotating about the z-axis means the ring/coil is actually spinning??
Yep!:smile:
hmmm..that clears it thanks!
so what's the answer?
x axis
An emf will not be induced in the coil if it rotates around the y axis. This is because the flux linked to the coil is the dot product of its area and the magnetic field. As the coil rotates about the y-axis the angle between its area (normal to the plane of the coil) and the magnetic field remains at 90 deg. Hence the flux linked to the coil correspondingly remains zero during the rotation, and therefore the induced emf is zero.
Thus the answer to the problem is rotation about the x-axis only as already clarified. The above is only to elaborate further on the impact of rotation about the y axis.
