Mellin Transform: Poles & Gamma Function
  • Context: Graduate
  • Thread starter Thread starter knightrider
    Transform
The discussion revolves around the properties of the Mellin transform, particularly focusing on the locations of poles and their relationship with the Gamma function. Participants explore conditions under which poles may occur at integer values or elsewhere, examining both theoretical implications and specific examples.
  • One participant asserts that poles of the Mellin transform of an analytic function generally occur at non-positive integer values, citing the Gamma function as an example.
  • Another participant counters that while poles at integer values are common due to the Gamma function's properties, more complex functions may have poles elsewhere, suggesting that most functions can be approximated by poles at integer values but true transforms do not necessarily have them there.
  • A request for examples of functions with poles at non-integer values is made, emphasizing the need for analytic functions.
  • One participant proposes that by manipulating the Mellin transform through specific transformations, poles can be shifted away from integer values.
  • Concerns are raised about the implications of branch cuts and analyticity near the origin, suggesting that restrictions on the function may influence pole locations.
  • There is a discussion about the validity of power series expansions and their convergence, with one participant arguing that Taylor series provide exact representations within their radius of convergence, while another questions the notion of equality in this context.
  • References to specific mathematical literature are made to support claims regarding the behavior of Taylor series and their convergence properties.
Participants express differing views on the conditions under which poles of the Mellin transform occur, with no consensus reached on the implications of analyticity, power series expansions, or the nature of equality in mathematical representation.
Participants note the importance of conditions such as analyticity and the implications of branch cuts, as well as the limitations of power series expansions in representing functions outside their radius of convergence.
knightrider
Is the following statement correct?
The poles of the Mellin transform of a function analytic, say on a complex domain or the whole complex plane, occur in general at (perhaps non-positive) integer values.
It is true for the Gamma function.
No. The common occurrence is a result of the gamma function being the Mellin transform of the exponential exp(a*x); which in turn is the solution of differential equations with constant coefficients. In so far as your problems are reducible to this then poles at integer values will show up; but when you deal with more complicated problems the poles will generally be elsewhere.
There is also the result that expansion in terms of a Laurent series and then transforming the terms one by one will result in poles at integer values; corresponding to the powers of x.
Fully explaining the fact that some (actually most) transforms don't have poles there is not within my grasp, but I think it can be explained by Muntz's theorems (the current ones). Where some real and some complex functions can be approximated to arbitrary accuracy by series similar to the power series.
In summary: I think most functions can be approximated by poles at integer values, but the "true" transforms do not have them there.
Ray
Thanks for the response, Rrogers.
I agree with you there should be more restrictions on g for its Mellin transform to have simple poles at (negative) integers. I am experimenting with a few conditions.
Would you be able to give an example where the poles fall on non-integers, with g being analytic (preferably on the whole plane)?
Simple process:
Let M(f(x))=F(s) then proceeding formally M(f(x^a))=a^(-1) F(s/a)
Assuming F(s) has poles at integers then let a be irrational. We have moved all of the poles off of the integers.
Alternately the poles can be shifted uniformly by multiplying f(x) by [tex]x^{\beta}[/tex]
M[tex](\frac{1}{1+x})=\frac{\pi}{\sin(s\pi)}[/tex]
M[tex](\frac{1}{1+x^a})=\frac{\pi}{a*\sin(\frac{s}{a} \pi)}[/tex]
Or more fundamentally
[tex]M(e^{-\alpha x})=a^{-s}\Gamma(s)[/tex]
[tex]M(e^{-\alpha x^{u}})=(u^{-1}) a^{-\frac{s}{u}}\Gamma(\frac{s}{u})[/tex]
[tex]M(x^{\beta}e^{-\alpha x})=a^{-s-\beta}\Gamma(s+\beta)[/tex]
Or even more fundamentally just place two poles out in left field and invert (they have to occur in complex conjugate pairs for "real" functions):
[tex]F(s)=\frac{1}{s+(a+bi)}+\frac{1}{s+(a-bi)}[/tex]
then
[tex]f(x)=x^{(a+ib)}+x^{(a-bi)}=x^{a} \cdot 2 \cdot cos(b \cdot ln(x))[/tex]
Unstated conditions abound for the above, and you should always check things I write. I am really really notorious for misstating things the first time around; even the most obvious.
Ray
Good examples, Ray.
On the other hand, the examples you offered where the poles are not on the integers all have branch cuts at the origin. I think restricting the function f to be analytic at least in the vicinity of the origin should force the poles of its Mellin transform in the left half complex plane onto the non-positive integers.
I don't see how. Some more explanation or an example would help.
I don't see how the third (partial fraction) example is affected since the source terms are single valued.
Ray
For your second line, the partial fraction source [tex]x^{(a+ib)} =e^{(a+ib)\ln(x)}[/tex] where [tex]\ln(x)[/tex] is multi-valued with value difference [tex]i 2\pi[/tex].
I will elaborate on the your first question later.
Ray, here is the solution to your first question. For a function analytic in the vicinity of the origin, expand the function in power series within a radius r. Break the Mellin integral into two parts, from 0 to r, and from r to infinity. Term by term integration of the first part produces a meromorphic function with simple poles at non-positive integers, whereas the second integral results in an analytic function. And we are done.
I believe you are "begging the question". Suppose the real expansion was the order of x^(1/2)
Now you _can_ expand in terms of the taylor series but it's just an approximation.
Like I said the taylor series can be used to expand functions but it's basically an approximation; not the "truth"; whatever that is.
Ray
Ray, I don't quite understand what you are saying.
A complex function is analyticity at a point if and only if it has (non-negative integer) power series expansion in an open disk of that point. The series will not contain terms like x^(1/2). The series is not just approximation but converges uniformly in that disk, therefore can be integrated or differentiated term by term. I suppose what you mean by "truth" is exact equality. The power series equals exactly to the original function in that disk.
I haven't double checked but I am pretty sure:
The Taylor series (like other Muntz series) are merely dense in Analytic (and more general) functions. Like the rational numbers are dense in the real line; pi is not a rational number.
Disclosure: I am a unrepentant Platonist.
Well the first book I checked disagree's with me. I will check further for a reference.
Ray
"The power series equals exactly to the original function in that disk"
Since I haven't found a reference yet, let's consider your statement. If the Taylor series were anything but a close approximation then you wouldn't have to confine it to a "disk".
Furthermore using it as a substitute for the real function is only valid on that disk. Since it diverges at the first complex pole you can't do the necessary semicircle closure for finding the Mellin transform. Also, as I remember the series doesn't converge anywhere on the edge; even where the original function has well defined finite values.Ray
At last I found positive references. The case of 1/(1+x^2) expanded around zero. It certainly is well defined but the taylor series starts making bigger and bigger errors after x>2. None the less it does have a Mellin xform.
The discussion of this point is on Page 151 of Buck's "Advanced Calculus" 1978. I can dig up the Bibtex entry if you want.
Ray
Let's deal with the issues one at a time.
1. Have you read carefully read my last post and noticed that, I cut the integrating region, i.e., the positive real axis, into two parts, [0 r) and [r,\infty), where r is less than the radius of convergence --- beyond which the power series diverges ----- of the power (Taylor) series around 0? I integrate the power series term by term in the first interval and integrate the function in the original form (not Talyor series!) the rest of the real axis.
Note that the poles appear only when you analytically continue the fundamental region of the s complex plane post Mellin transform to the left of the fundamental region.
I will elaborate on these points if you still object to the treatment.
2. On the issue of denseness of the Taylor series. The correct statement is the set of finite partial sum of a power series is a dense subset of the set of the analytic function. The set of Taylor series, or power series, includes all infinite sums and thus the limit points. So the set is complete and equal to the analytic function set.
3. Each power series around a specified point has a radius of convergence, inside which the series converges to the original analytic function, and beyond which it diverges. The radius of convergence of your function 1/(1+x^2) around 0 is 1. That is why you found the Taylor series "starts making bigger and bigger errors after x>2". In fact it will do so not only for x>2, but once |x|>=1.
I guess we disagree about "equality".
When you get a chance, I do think you should look at the Muntz polynomials and think about Muntz's closure theorem.
Ray
Hmm, to pin point the dividing line, let me ask you two questions:
1. do you agree with the following statement?
[tex]f(x) \stackrel{\text{def}}{=}\frac{1}{1-x} = \sum_{n=0}^\infty x^n, \forall |x|<1,[/tex]
where [tex]x[/tex] is complex.
2. what is your definition of an analytic function?
1) Basically no. Restricted to the reals and [0,1) they have the same value. But I can do things to the left hand, integrate in a tight circle in the complex plane around 1, that I can't do to the series; and get the same value. That and the restriction lead me too say they are different functions.
2) I would stick to the old definition; the Cauchy condition of having a derivative in the complex plain.
1. Please note I did not ask anything about the situation |x|>=1, but only |x|<1, the open disk of unit radius centered around 0 of the complex plain. If you integrate round 1, you are going outside the unit disk where question 1 has no comment. You are not answering the question I am asking. Can we strictly stick to the question for now?
2. You mean being continuously differentiable on an open set in the complex plane, right? We will come back to expand on this topic later.
1) I agree the two expressions have the same values in the limited domain.
2) Yeap
Ray
OK. What is then your objection to my previous statement "The power series equals exactly to the original function in that disk", where the disk is of radius of convergence, specifically in reference to question 1? Do we not agree on the meaning of equality? Note the power series is the same of the Taylor series.
I'll skip discussing the formal definition of "equality". In my mind it wanders off into topologies and equivalence relations. Not to mention, including Hyperreals; which I would have to study a lot.
Reset:
As I interpret it, you propose to replace the Mellin part of:
[tex] F(s)=\frac{1}{s+(a+bi)}+\frac{1}{s+(a-bi)}[/tex]
[tex] f(x)=x^{(a+ib)}+x^{(a-bi)}=x^{a} \cdot 2 \cdot cos(b \cdot ln(x))[/tex]
With a series of poles on the negative integers; and keep all of the functionality that Mellin transform theory provides.
You would have to demonstrate that to me.
Ray
Could we please not wander and waste time, could we please be effective and stay on the topic at hand?
Let me restate my claim and see if you agree with it.
f(x) is a function defined on the positive real axis so that its Mellin transform F(s) exist in a fundamental strip [tex](0,\beta)[/tex], where \beta is a positive real number. f(x) is also analytic at 0 (meaning in a neighbourhood of 0 on the complex plane). The F(s) is analytically continuable to a meromorphic function in the left half complex plane (Re(s)<=0) with simple poles at and only at the nonpositive integers.
Ray, I have a question concerning your example above in post #21 of a Mellin transform. There does not exist an s such that the Mellin transform converges as a complex valued function on the complex plane. I wonder if this could be defined as a distribution, such as the Dirac delta function, instead of a function in the normal sense. If it is so, perhaps you could elaborate on how this distribution is exactly defined.
"I have a question concerning your example above in post #21 of a Mellin transform. There does not exist an s such that the Mellin transform converges as a complex valued function on the complex plane."
Could you explain why you think that? It seems to fit all of the requirements. existence of the integral and such.
I am studying the relationship between Distributions and Mellin xforms. Learning a lot about both, but the source materials I have don't seem to be "correct". But I haven't worked my way through the alternate domains and convolutions yet; so I could very well (probably) be wrong.
Ray
Try integrating [tex]\int_0^\infty x^{a-1} dx[/tex] and tell me what real number a would make the integral convergent.
What's your comment on #22?
Your absolutely right! If you look at my original inverse transform I closed the contour to the left and the vertical line was to the right (fairly standard) and that implicitly has x<1; with 0 resulting if you close on the other (Re(s)>inf) side This is also justified because the forward xform works with x^(a)*H(x-1) ; presuming a real. If a is complex we need the complex conjugate function to yield a real valued function.
Thus the "normal" expression should have had a conditional x<1. and have the value 0 for x>1 .
The different function that has the integration line to the left and close to the right you get the negative function. for x>1.
As for #22 I don't have a firm statement to make yet. There is a counter example; but it's a cheat. I _think_ that the real answer is similar to the above. You can adjust poles outside of the complex plane closure to make similar values appear in the inverse transform as some given non-integer pole. But subsequent manipulations in the Mellin/complex plane may or may not yield similar values.
I am not certain, so I would need to fabricate an example of the failure; maybe lthough zero/non-zero closure Examples could be with differentiation; where a _true_ function (and it's Mellin xform) is perfectly well behaved but differentiation of the Taylor series becomes divergent. Say the expansion of 1/(1-x) (I think).
Ray
Ray, it does not expend much to write down the full functional value, a simple 0, on [0,1] for f(x) in you previous several post. It would have saved a lot of unnecessary back and forth and time with a smidgen of care if not rigour.
Anyway, your example still does not negate my claim, unless you show me otherwise.
  • · Replies 0 ·
