Induced emf in a falling wire aligned with Earth's magnetic field components
The discussion confirms that a falling metallic wire, when aligned with both the geographic east-west and north-south directions, will experience induced electromotive force (emf) due to its interaction with the Earth's magnetic field. The relevant equation is E = -d(phi)/dt, where phi represents the magnetic flux intercepted by the wire. The wire cuts through the horizontal component of the Earth's magnetic field, resulting in induced emf in both orientations due to the perpendicular components of the magnetic field. The alignment of magnetic north and geographic north does not affect the induction process, as the wire intercepts the horizontal magnetic field components.
  • Understanding of electromagnetic induction principles
  • Familiarity with the equation E = -d(phi)/dt
  • Knowledge of Earth's magnetic field components
  • Basic concepts of magnetic declination
  • Study the principles of electromagnetic induction in detail
  • Learn about the Earth's magnetic field and its components
  • Explore the effects of magnetic declination on induced emf
  • Investigate practical applications of induced emf in engineering
Students of physics, educators teaching electromagnetic theory, and engineers working with electromagnetic applications will benefit from this discussion.
kihr
Whether a length of metallic wire, if placed in the geographic (a) east-west, and (b) north-south directions, and dropped freely from a height, would have an induced emf or not.
E= - d(phi)/dt, where phi = flux intercepted by wire
The magnetic field of the Earth has a vertical and a horizontal component, both of which lie on the magnetic meridian. The horizontal component (in the plane of the magnetic meridian) would further have components along the geographic N-S and E-W directions depending on the magnetic declination at the given point on the Earth's surface. Thus for (a) the falling piece of wire would cut the horizontal component of the Earth's magnetic field acting along the geographic N-S direction, and an emf would be induced. For (b) the wire would cut the horizontal component of the Earth's magnetic field acting along the geographic E-W direction, and here again an emf would be induced in the wire.
I would appreciate if the correctness of above could be confirmed. Thanks.
Basically what you are saying is that the magnetic north and geographic north do not align, so in either option there is some perpendicular component of the field, so there is an induced emf, which is correct.
The perpendicular component of the Earth's magnetic field is not intercepted by the wire irrespective of whether it is aligned along the geographic N-S or E-W direction. However, the component of the Earth's horizontal magnetic field (i.e. in the plane of the magnetic meridian) along the geographic N-S and E-W directions do get intercepted by the falling wire aligned along the E-W and N-S directions respectively. This gives rise to the induced emf. I hope I have been able to make my point of view clear. Thanks.
