Collision between falling body and body shot upwards
The problem involves two balls: one dropped from the top of a 22m building and another thrown upwards at 22 m/s from ground level. The objective is to determine the distance from the ground where the two balls meet, considering kinematic principles without the use of calculus.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the concept of collision in terms of displacement and question how to express the relationship between the two balls' movements. There are attempts to set up equations based on their respective displacements and time of travel.
Some participants have provided hints regarding the relationship between displacement and time, suggesting that both balls must collide at the same time. There is an acknowledgment of the need to establish two equations with two unknowns, leading to further exploration of the problem.
Participants note that air resistance is negligible and that the problem must be solved using basic kinematic equations, avoiding calculus-related methods.
jasper619
Hi this is my first post thanks to who ever contributes!
A man drops a ball from the top of a 22m building. At the same instant his friend below throws a ball upwards at 22 m/s. What distance from the ground do the two balls meet.
Ball A
v1 = 0 m/s
a = 9.8m/s down
t=?
d=?
Ball B
v1 = 22 m/s up
a = 9.8 m/s down
t = ?
d = ?
This assumes that ball A was dropped right at 22m and the other ball was thrown from ground level. Air resistance is negligible.
My attempts have all failed my general approach was to solve for time that they hit at and then use that to find the distance one of the balls traveled. We are to use basic equations relevant to kinematics, force or energy (no calculus related stuff). Any help would be much appreciated
Jasper
Welcome to Physics Forums.
HINT: In terms of the balls' displacement, what does a 'collision' mean?
well wouldn't a collision be when the displacements overlap?
If the balls collide at a height d0 above the ground, then the displacement of ball B is d=d0. What is the displacement of ball B?
If you meant what is the displacement of ball a then it is d = 22 - d0 right?
hmm wait I think i know what to do now I will post my result
Indeed I did and that is correct. :smile:
I don't know what to do with time as all my formulas ask for it any tips would be nice
My hint is pretty much the same as for the displacement: the balls must collide at the same time. You should be able to write down two equations, one force each ball. Each equation should have two unknowns - time and displacement (don't forget to use the previous hint for displacement). Now, you have two equations with two unknowns - how would you usually go about solving this type of problem?
Ya i figured it out thanks a lot
  • · Replies 38 ·
  • · Replies 23 ·
