| Thread Closed |
Determine the amplitude of a mechanical wave given only it's velocity and period |
Share Thread |
| Sep1-09, 10:25 PM | #1 |
A transverse sinusiodal wave on a string has a period T= 25.0 ms and travels in the negative x direction with a speed of 30.0 m/s. At t=0, an element of the string at x=0 has a transverse position of 2.00 cm and is traveling downward with a speed of 2.00 m/s. 2. Relevant equations I know that the general equation for a waveform is: y(x,t)= Asin(kx-(omega)t+(phi)) {omega is the angular frequency and phi is the phase constant} I also know that at t=0 and x=0 y(x,t)=.02 m --> .02=Asin(phi) --> A=.02/sin(phi) I can also determine omega given the period: omega=(2*pi)/.025=251.3274 rad/s 3. The attempt at a solution Even with my relevant equations, I cannot figure out what I am supposed to do with the extra known factor, velocity. I have scrubbed the current chapter and can't find where I can use the transverse position, angular frequency and velocity in the y direction to determine a waves amplitude. What am I missing? Please help! I have so many problems to do but I just can't do another one until I figure this out! Thanks so much. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Sep2-09, 05:02 AM | #2 |
There`s certainly a way of getting A with that data. IŽll be glad to explain it to you but it's a little heavy, I mean all the calculations.
Let's start: we are given the constants of the wave T which, as you said, give us w (omega) and v which give us k (by the relationship v=(lamda)/T and from that k=2·(pi)/(lamda) ). We also have the elongation y(0,0)=Yo (i know the data is numerical but in order to have it more simple weŽll work with letters) and the velociti of that point at that time Vy(0,0)=Vo. (I think this is the fact that you misregarded in your first post) Ok then we can write the eq. like this (as you did): y(x,t)=A·sin(kx-wt+&) [& is (phi)] the first condition we know is y(0,0)=Yo , lets write it: y(0,0)=A·sin(k·0-w·0+&)=A·sin&=Yo -> A·sin&=Yo first relationship between unknown & and A. Now we use the fact that velocity of the point x=0 at t=0 is 2m/s downwards which makes: Vo=-2 m/s so weŽll work with Vo. You should remember or know that the velocity of a point at a moment is given by the partial derivative with respecto to time of the wave function y(x,t)=... So lets differenciate: [tex]\partial[/tex]y/[tex]\partial[/tex]t=-Aw·cos(kx-wt+&) so, Vy(0,0)=-Aw·cos(K·0-w·0+&)=-Aw·cos&=Vo -> -Aw·cos&=Vo Second relationship between unkanown A and &. Now you just have to solve the eqs. system: A·sin&=Yo A·w·cos&=Vo |
| Sep2-09, 05:10 AM | #3 |
My personal advice with the system is to divide first eq. by the other and write the new eq. (without A) like this:
sin&=(w·Yo/Vo)·cos& And the use the trigonometric relationship sin2&+cos2&=1 in order to get the expression of sin& (as we want A, not &) then once you've done all the calculations just put the expression you get for sin& in the one of the first eqs. which had sin& on it: A·sin&=Yo -> A=Yo/sin& And there you have your solution. Hope it is worth and hope I made myself clear. If you have any other trouble just tell me. Salutations, zaphys. :) |
| Sep2-09, 05:26 AM | #4 |
Recognitions:
When a transverse sinusoidal wave travels on a string, every element of the string executes simple harmonic motion. Its equation is given by
y = A*sin(ωt), where y is the transverse displacement, A is the amplitude and ω is the angular velocity = 2π/T. The transverse velocity is given by dy/dt = A*ω*cos(ωt) = ω*sqrt[ A^2 - A^2*sin^2(ωt)] = ω*sqrt[ A^2 - y^2] Angular velocity, transverse velocity and transverse displacement is given. Find the wave amplitude. |
| Sep2-09, 08:30 AM | #5 |
Why didn't I see that? Thank you so much...(solving for A reveals the amplitude to be 2.15 cm).
I think I just hit the wall in my head where I am not thinking holistically about the problem. Thanks again. |
| Sep2-09, 03:28 PM | #6 |
Wait a second, rl.
How did you come up with that equality for the derivative of the waveform? I think that was what I was actually looking for! |
| Sep2-09, 07:20 PM | #7 |
Recognitions:
| Sep24-09, 09:21 PM | #8 |
| Sep29-09, 09:53 PM | #9 |
guess i get no love with this request---
| Sep29-09, 10:49 PM | #10 |
Recognitions:
| Sep29-09, 10:59 PM | #11 |
No worries! In my mind, I picture a circle that has a radius equal to A. Where the angular frequency is the rate at which A fluctuates from +A to -A in radians per second. I am just not sure what that really looks like or if I am way of base. Your equation says that if I know the transverse position and the angular frequency then I can determine the amplitude. I am just trying to figure out how this all ties together because I think it's an important fundamental concept. Thanks for the try.
| Thread Closed |
| Tags |
| amplitude, mechanical waves |
Similar discussions for: Determine the amplitude of a mechanical wave given only it's velocity and period
| How do you determine the amplitude of a wave exhibiting simple harmonic motion? | Classical Physics | 2 | ||
| Wave Velocity, Amplitude & Phase change | General Physics | 0 | ||
| Amplitude and Period | Introductory Physics Homework | 7 | ||
| Velocity, Period, and Transverse Wave | Introductory Physics Homework | 1 | ||
| what happens to the maximum velocity if you double both Amplitude and period of a SHM | Introductory Physics Homework | 1 | ||
