| Thread Closed |
Laplace Transform Convergence |
Share Thread | Thread Tools |
| Sep2-09, 12:40 AM | #1 |
I've been trying to understand what the Laplace Transform means via It's definition. Even if you are trying to evaluate a simple exponential function:
[tex]F(s) = \mathcal{L} \left\{f(t)\right\}=\int_0^{\infty} e^{-st} f(t) \,dt. [/tex] it will not converge for all S in a Riemann sense. I've been trying to read a bit about measure theory and Lebesgue integration and what I found on the web hasn't made me feel like I understand much. However, I did read two things that seem to show how I might be able to make the Laplace transform converge for all S. 1) The Unit Step functions form a Lebesgue measure for the Laplace Transform. 2) Lebesgue integration can be thought of in terms of partitioning in a vertical sense instead of a horizontal sense. Okay, so what is the Laplace Transform for a unit step function? It is: [tex] u(t-\tau) \ ={ e^{-\tau s} \over s } [/tex] Now, we can partition an exponential function in to horizontal rectangles as follows [tex]exp(\lambda t)=u(0)+\Delta y\sum_{n=1}^{\infty}u\left(t-\frac{1}{\lambda}ln\left(\ n\Delta y\right)\right)[/tex] Using the linearity property of the Laplace transform: [tex] \mathcal{L}(exp(\lambda t))=\frac{1}{s}+\Delta y\sum_{n=1}^{\infty}{ e^{-ln(\ n\Delta y)\frac{s}{\lambda}} \over s } [/tex] [tex] \mathcal{L}(exp(\lambda t))=\frac{1}{s}+\Delta y\left(\frac{1}{\Delta y}\right)^{s/\lambda}{\sum_{n=1}^{\infty}\left(\frac{1}{n} \right)^{s/\lambda} \over s }=\frac{1}{s}+\left(\frac{1}{\Delta y}\right)^{(s/\lambda)-1}\frac{\zeta(s/\lambda)}{s}[/tex] (Which doesn't converge so I need to do something different :(). |
| Sep2-09, 02:58 AM | #2 |
I don't think vertical partitioning helped.
Maybe if the function is [tex]exp(\lambda t)[/tex] Then I can choose as basis (measure?) Functions of the form [tex]exp(\beta(t-\tau)) [/tex] That is delayed exponential (probably a negative exponential if lambda is positive). Let: [tex]b_0=f(0)exp(\beta t)[/tex] [tex] b_n=\left<f(x)-\sum_{k=o}^{n-1}b_kexp(\beta t-n \Delta t) \ , \ f(exp(\beta(t-n \Delta t))\right> [/tex] The inner product is taken from zero to infinity. Now if I express this sequence in the Laplace domain, can I find for any S a value of [tex]\beta[/tex] for which the sequence will converge. Also if I do this and I only approximate a few terms then what is the rate of convergence for all points in the Laplace domain. |
| Sep3-09, 12:04 PM | #3 |
I'm not sure why the following premises in quotes is wrong but in my example I approximate f(x) arbitrarily closely and the limit in the Laplace domain doesn't converge to the correct value (or at least the limit is not well defined.
[tex]f(x)=e^{at}[/tex] Let this function be bounded by: [tex]f(x)=e^{bt}[/tex] Now I can show that (I'll prove this in another post): [tex]f(x) \approx e^{bt}+\sum_1^{\infty}(e^{na\Delta t}-e^{(b+(n-1)a)\Delta t})e^{-b(t-n \Delta t)u(t-\Delta t)[/tex] Now, because the Laplace transform is linear we have: [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\sum_1^{\infty}({e^{na\Delta t}-e^{b+(n-1)a\Delta t})\frac{e^{-bn \Delta t}}{s-b}[/tex] or equivalently: [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\sum_1^{\infty}({e^{n(a-b)\Delta t}-e^{(n-1)(a-b)\Delta t})\frac{1}{s-b}[/tex] Writing as a geometric series: [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\frac{1}{s-b}\sum_1^{\infty}\left(\left({e^{(a-b)\Delta t}\right)^n-\left(e^{(a-b)\Delta t}\right)^{(n-1)}\right)[/tex] [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\frac{1}{s-b}\mathop {\lim }\limits_{N \to \infty }\left(\sum_1^{\infty}\left({e^{(a-b)\Delta t}\right)^n-\sum_1^{\infty}\left(e^{(a-b)\Delta t}\right)^{(n-1)}\right)\right[/tex] [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\frac{1}{s-b}\mathop {\lim }\limits_{N \to \infty }\left(\frac{(e^{(a-b)\Delta t})^{N}}{1-e^{(a-b)\Delta t}}-\frac{(e^{(a-b)\Delta t})^{N-1}}{1-(e^{(a-b)\Delta t}}\right)[/tex] [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}+\frac{1}{s-b}\mathop {\lim }\limits_{N \to \infty }(e^{(a-b)\Delta t})^{N}\left(\frac{e^{(a-b)\Delta t}-1}{1-e^{(a-b)}}\right)[/tex] [tex] \mathcal{L}(f(x)) \approx \frac{1}{s-b}-\frac{1}{s-b}\mathop {\lim }\limits_{N \to \infty }(e^{(a-b)\Delta t})^{N}[/tex] Which doesn't seem like a terribly useful limit because it depends how quickly [tex]\Delta t[/tex] approach zero as N approach infinity also if b can very with the limit the expression is even more ambiguous. |
| Sep3-09, 01:02 PM | #4 |
Actually come to think of it my approach is all wrong. So my above premmis again:
Define the Laplace as follows: [tex]\mathcal{L}(f(t))=\mathop {\lim }\limits_{t \to \infty} \int_0^{t} f(t')(1-u(t'-t))e^{-st'}dt'[/tex] Then it is easy to show that at least for an exponential function that this converges to the Laplace transform. So, I think what I want to do is develop a limit approximation for a finite length, Compute the Laplace transform and then take the limit as L approaches infinity in the Laplace domain. So one limit in the time domain and another limit in the Laplace Domain. |
| Sep5-09, 07:38 PM | #5 |
I found some interesting stuff:
Here is some more stuff on the Hankel Norm: http://ocw.mit.edu/NR/rdonlyres/Elec..._6245_2004.pdf http://www.eurasip.org/Proceedings/E...ers/cr1875.pdf |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Laplace Transform Convergence
| Laplace transform | Calculus & Beyond Homework | 0 | ||
| Finding an inverse Laplace Transform for a function - solving IVPs with Laplace | Calculus & Beyond Homework | 2 | ||
| Laplace Transform of cos(at) * cos(bt) | Electrical Engineering | 2 | ||
| The difference between Fourier Series, Fourier Transform and Laplace Transform | General Physics | 1 | ||
| Laplace Transform | Differential Equations | 2 | ||
