Understanding ZnO Photocorrosion & Techniques for Analysis | Rohini
  • Thread starter Thread starter rohinikitture
The discussion focuses on the photocorrosion of Zinc Oxide (ZnO) in photocatalytic applications, specifically in the degradation of Methyl Orange dye. Photocorrosion refers to the chemical reaction induced by light, leading to the transformation of ZnO into Zn(OH)2 in aqueous environments. Techniques such as Fourier Transform Infrared Spectroscopy (FTIR) are suggested for detecting the formation of Zn(OH)2, although alternative methods may also be considered for quantitative analysis.
  • Understanding of photocatalysis and its applications
  • Knowledge of photocorrosion phenomena
  • Familiarity with Fourier Transform Infrared Spectroscopy (FTIR)
  • Basic chemistry of Zinc Oxide and its reactions in aqueous solutions
  • Research the mechanisms of photocorrosion in ZnO under various light conditions
  • Learn about alternative detection methods for Zn(OH)2 formation, such as UV-Vis spectroscopy
  • Explore quantitative analysis techniques for photocatalytic efficiency
  • Investigate the stability of ZnO in different chemical environments
This discussion is beneficial for researchers and students in materials science, environmental chemistry, and chemical engineering, particularly those focusing on photocatalytic processes and the stability of photocatalysts like ZnO.
rohinikitture
Hope I will get help in this regard.
I am studying application of ZnO for photocatalysis, dye degradation. I came across a comment that ZnO also shows photocorrsion.
I wish to know what do they mean by Photocorrosion, and is there any technique to know whether it occurs or not. And if yes, then is there any method for its quantitative analysis.
Rohini
In what environment is the ZnO. Corrosion normally implies a chemical reaction. Light may promote a photochemical reactions, e.g., ZnO + H2O + light => Zn (OH)2 (aq). Otherwise, perhaps this might be erosion or evaporation.
@Astronuc
Thank you for the reply...
I am using ZnO in water, that already contains dye-Methyl Orange.
If there is formation of Zn(OH)2, then will it be possible to detect it thru FTIR? or should I choose some other technique?
  • · Replies 92 ·
  • · Replies 21 ·
