| Thread Closed |
Why does elecricity kill? What causes a magnet to be a magnet? |
Share Thread | Thread Tools |
| Sep2-09, 06:04 AM | #1 |
Just a couple of simple questions.
1-Why does electricity kill? 2-What causes a magnet to be a magnet and certain things magnetic? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep2-09, 06:09 AM | #2 |
1. Electricity in itself does not kill. As a matter of fact, it does not even hurt. What is dangerous about electricity is the combination of many electrons travelling (amperage) at very high "energy" (voltage). Without this combination, there is no danger.
2. The magnetic property of matter, from the elementary point of view, comes from the movement of electrons around the nucleus. Cheers |
| Sep2-09, 06:19 AM | #3 |
What does high amperage and voltage do to kill? Like does it do anything to the heart or brain etc. And what type of movement causes magnetism?
| Sep2-09, 06:22 AM | #4 |
High amps and voltage causes severe burn on the body. If it travels through vital part, it will burn them, leaving you very little chance.
Before going any further, do you know what creates a magnetic field??? |
| Sep2-09, 06:27 AM | #5 |
Sorry I don't know.
| Sep2-09, 06:34 AM | #6 |
Hi there,
That's fine. But it might important to understand where magnetism comes from, before trying to understand magnetism in matter. Ok, let's start from the start. Electric charges create an electric field. This electric field can interact with another electric field to develop a force on the initial charge. I hope you are following me up to now. Now, for magnetism, take the same electric charge and throw it, or just put it in motion. The movement of the electric charge now develops an extra magnetic field. Ok, so knowing that electrons are moving around a nucleus, each electrons creates a small magnetic field. Having many electrons orbiting, the magnetic field from each can be either increase or destroy the magnetic field of the others. Right. Cheers |
| Sep2-09, 06:39 AM | #7 |
Thanks a lot. If I am not annoying you can you tell how the magnetic field of one electron in creases or decreases the other's? does the direction of its spin have any effect?
| Sep2-09, 06:46 AM | #8 |
Forget about the electron spin. Don't think of the electron in an quantum mechanics mannet. Stick to the classical theory.
Take the helium atom as a simple example. To make it really simple, take Bohr's representation of the atom. The helium atom has two electrons orbiting the nucleus. One electron creates a magnetic field. No problem up to now. The second electron also creates a magnetic field. To see the total magnetic field of the atom, you must sum the field created by the two electrons. In this case, the sum can be additive or destructive. Cheers |
| Sep2-09, 06:49 AM | #9 |
Thanks for explaining in a simplified way.
| Sep2-09, 07:38 AM | #10 |
Recognitions:
2) There are different kinds of magnets: ferromagnets/ferrimagnets, paramagnetics, and diamagnetics. The first two are 'permanent' magnets, in that they generate a magnetic field all by themselves. The other two describe how materials respond to an applied magnetic field; either by becoming oriented with (paramagnetism) or opposed to (diamagnetism) the applied magnetic field. If we are discussing the phenomena in terms of classical physics, the situation is analogous to the polarization of a dielectric. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why does elecricity kill? What causes a magnet to be a magnet?
| ur in a room with a magnet and an iron bar how do u know which one is the magnet | Introductory Physics Homework | 23 | ||
| Amount of force 1 magnet with"x"electric energy can create against an opposing magnet | Classical Physics | 1 | ||
| Would running an electrical current through a magnet destroy the magnet? | General Physics | 4 | ||
| why the poles parts of the magnet are stronger then the other parts of the magnet? | Classical Physics | 2 | ||
| what make the magnet to be magnet with magnetic field? | General Physics | 23 | ||
