Does a constant electric flux produce a current?
The discussion revolves around the relationship between electric flux and current in a wire with a potential difference. Participants explore the implications of a constant electric field and the application of Gauss' theorem in this context, questioning the conditions under which a current can exist despite a seemingly constant electric flux.
  • One participant presents a scenario where a wire has a potential difference leading to a constant electric field, questioning why the calculated current appears to be zero despite the presence of an electric current.
  • Another participant asks for clarification on the integration surface and the meaning of the variable "x" in the context of the problem.
  • A participant emphasizes that the Gaussian surface must be closed, noting that current flows in and out, which affects the integral used in the analysis.
  • There is a discussion about the implications of a constant electric field leading to constant electric flux, with one participant arguing that this results in zero current when applying Gauss' theorem.
  • Another participant suggests that while Gauss' law relates charge to electric field, it requires a closed surface, leading to zero flux in this case, and proposes considering the Lorentz force instead.
  • One participant mentions that a constant electric field can indeed create current in certain models, such as in a MOSFET, where current is influenced by various physical constraints.
Participants express differing views on the application of Gauss' theorem and the conditions under which a constant electric flux can produce a current. There is no consensus on the resolution of the initial question, and multiple competing interpretations remain.
Participants highlight limitations in the application of Gauss' theorem, particularly regarding the need for a closed surface and the implications of a constant electric field. The discussion also touches on the need for additional knowledge about charge behavior in electric fields.
eoghan
Hi! Suppose I have a wire with a potential difference V=bx where b is a constant. Then there is an electric field which is constant: E=b through out the wire. Well, now consider this relation:
[tex]I=\frac{dq}{dt}=\frac{d}{dt}\epsilon_0\int{\vec{E}\cdot\hat{n}dS}=\epsilon_0 S \frac{dE}{dt}=0[/tex]
where I used the Gauss' theorem and the fact that E is constant.
From this relation then follows that the electric current is 0! But I do have an electric current in the wire! Where am I wrong?
What surface are you integrating over, what does "x" stand for? Could you explain the problem a little more so that I can help you, personally I can't see it. Thanks
Your Gaussian surface must be closed. The current flows in one side and out the other, which is why the integral is zero.
Let's say that the wire lies along the x axis.. then x represents a point of the wire. I integrate over a surface perpendicular to the wire in a point x with the center on the wire. But the surface is meaningless, what matters is that if E is constant in time, then its flux will be constant in time (if the surface is constant in time).
Yes, but if you define I=dq/dt then you have I=d/dt (flux(E)) which is zero. With the Gauss' theorem I don't get the net current in the surface (which is zero), but the charge.
Have it your way, but I thought you said "I used the Gauss' theorem".
clem is correct here, you used Gauss' Law to relate the charge to the electric field, but Gauss' law requires a closed surface and since you have a spacially constant electric field you will always have zero flux. You should instead try the Lorentz force, however, you would need knowledge of the saturation velocity of charges, otherwise the constant force over an infinite wire will create infinite current.
Still, in respect to your original question, yes, a constant flux can create current. I know that in a simple MOSFET model, we assume that there is a constant electric field between the source and drain which results in a current. The amount of current is limited by the finite cross-sectional area of the transistor, the finite length of the transistor, and the finite saturation velocity of the mobile carriers.
  • · Replies 29 ·
  • · Replies 30 ·
