Register to reply
Force of Tension
by pointintime
Tags: force, tension
Share this thread:
pointintime
#1
Sep6-09, 09:31 AM
P: 166
Tarzan plans to cross a gorge by swinging in an arc from a hanging vine. If his arms are capable of exerting a force of 1400 N on the rope, what is the maximum speed he can tolerate at the lowest point of his swing? His mass is 80 kg and the vine is 4.8 m long?
2. Relevant equations
net force = ma
3. The attempt at a solution
I'm not sure how to deal with the force of tension in this problem
net force radial direction = m a radial direction = Fr = Ft + Farm - Fg
sense I don't know what the force of tension is in this problem I got down to this
v = ((.06 kg^-1 m)Ft - 37 s^-2 m^2)^(2^-1)
is the force of tension equal to what?
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Doc Al
#2
Sep6-09, 09:37 AM
Mentor
Doc Al's Avatar
P: 41,323
Quote Quote by pointintime View Post
Only consider the forces acting on him. How many forces act on Tarzan?
How does Farm relate to Ft?
pointintime
#3
Sep6-09, 09:45 AM
P: 166
oh F arm is equal to Ft ???
what about the force of gravity does that increase the force of tension sense his mass is pulling him downwards and his force of his arm is pulling him upwards?
confused on which force act upwards and which act downwards
tension pulls up
force exerted by arm is up
gravity is down
radial force is upwards
does Ft = Farm
Fg doesn't have any thing to do with tension in this case?
Doc Al
#4
Sep6-09, 09:49 AM
Mentor
Doc Al's Avatar
P: 41,323
Force of Tension
Yes! The force that he pulls on the rope equals the force that the rope pulls on him. (Opposite direction, of course.)
Answer my question: What forces act on the man? (Hint: Only two forces act on him.)
pointintime
#5
Sep6-09, 10:01 AM
P: 166
gravity and tension how
but home come gravity dosen't also pull the rope down creating tension
and what about centripetal force?
Doc Al
#6
Sep6-09, 10:07 AM
Mentor
Doc Al's Avatar
P: 41,323
Yes, gravity (down) and tension (up) are the only two forces acting on the man.
Gravity pulls the man down, which ends up creating tension in the rope (since the man pulls on the rope). We treat the rope as massless, thus there's no gravity acting directly on the rope.
Centripetal force is just the name given to the net force in the radial direction when something is centripetally accelerated (like in this example). It's not a separate force--it would not appear on a force diagram. When you apply Newton's 2nd law, then you'll use centripetal acceleration.
pointintime
#7
Sep6-09, 10:12 AM
P: 166
so the force of tension is just equal to the tension he exerts on his arm what about the force of gravity acting on the man pulling the man down and as a result pulling the rope down even more
the force of tension in the rope
f arm points upwards
force of gravity pulls the man downards creating more tension in the rope
so does the force of tension in the rope equal the force exerted by arm - the force of gravity acting on the man
Doc Al
#8
Sep6-09, 10:20 AM
Mentor
Doc Al's Avatar
P: 41,323
The rope tension pulls up on him with the same force that he pulls down on the rope. (At some speed he will be unable to hold on any longer, since he can only pull with so much force. That's what you're trying to find.)
That will be factored in automatically as you write your equation.
No.
No matter what else happens, the man and rope exert equal forces on each other. That's Newton's 3rd law.
pointintime
#9
Sep6-09, 10:37 AM
P: 166
so i got 9.8 s^-1 m
Doc Al
#10
Sep6-09, 10:43 AM
Mentor
Doc Al's Avatar
P: 41,323
so i got 9.8 s^-1 m
How did you arrive at this result? Show your equation for Newton's 2nd law and how you solved for speed.
pointintime
#11
Sep6-09, 10:50 AM
P: 166
net force = m a = Ft - Fg
net force = m a = 1400 N - (80 kg)(9.8 kg^-1 N)
net force = m a = 1400 N - 784 N
net force = m a = 616 N
r^-1 m v^2 = 616 N
v^2 = m^-1 r 616 N
v = (m^-1 r 616 N)^(2^-1)
v = ( (80 kg) 4.8 m (616 N) )^(2^-1)
v = 6.1 s^-1 m
so on free body diagrams we do not lable the centripetal force because it's not a seperate force but just the name of the net froce?
Doc Al
#12
Sep6-09, 11:24 AM
Mentor
Doc Al's Avatar
P: 41,323
r^-1 m v^2 = 616 N
v^2 = m^-1 r 616 N
v = 6.1 s^-1 m
Good. (I would write the units as m s^-1 or m/s.)
Exactly.
Register to reply
Related Discussions
Tension force Introductory Physics Homework 1
Applied Force Vs. tension Force Introductory Physics Homework 1
Tension and force Introductory Physics Homework 17
Tension Force Introductory Physics Homework 3
Force of tension Introductory Physics Homework 1
