Acceleration in terms of velocity
The problem involves a particle experiencing an acceleration defined by the equation a = -3.0*v (m/s²), with given initial conditions for velocity and position. The objective is to express acceleration, velocity, and position as functions of time.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to manipulate the equations of motion and integrate to find relationships between acceleration, velocity, and position. Some participants suggest framing the problem as a differential equation, while others explore integration techniques to derive the velocity function.
Participants are actively discussing various approaches to tackle the problem, including setting up differential equations and integrating to find functions of motion. There is an acknowledgment of the complexity of the problem, and some guidance has been provided regarding the use of integration and differential equations.
There are indications of confusion regarding the relationship between acceleration and velocity, particularly in terms of the initial conditions and the behavior of the particle under negative acceleration. The original poster expresses uncertainty about achieving the correct initial conditions through their attempts.
yoamocuy
Hey, so I have a question that states that a particle is subject to an acceleration of a=-3.0*v (m/s^2), and I need to find the acceleration, the velocity, and the position of the particle in terms of time. The initial velocity, Vo, is 15 m/s, and the initial position, So, is 0m.
Attempt at a Solution
I've tried plugging in a*t+Vo in for v, solving for a, and integrating, but that doesn't give me a velocity of 15 m/s at t=0s. Also I have tried solving for 3 equations 3 unknowns in terms of time using the equations a=-3.0*v, v=a*t+Vo, and d=1/2*a*t^2+Vo*t+So. This gave me the correct initial velocity and position at t=0; however, when I graphed all three functions it seemed that this could not be the correct method either because the particle was moving more meters in 1 second on my distance graph then its initial velocity at that second, which could not happen because it had a negative acceleration.
I'm thinking that I somehow need to get my acceleration in terms of time by setting v= to ds/dt and using a definite integral of some sort, but I just can't manage to figure out how to get it done. Any advice would be great.
Hello and welcome to PF!
You are onto something here. This problem is essentially one of differential equations, since the equation given to you (a=3v) is of that form. The first step is to write this as a differential equation for velocity, which you can solve to yield your velocity time function. Then you could either solve the second order differential equation from the a=3v, or integrate this velocity function, whichever you prefer.
You can solve by integration.
Now a = dv/dt = -3.0*v
Int.dv/v = -3.0*Int(dt)
log(v) = -3.0*t + logC At t = 0, log(v) = log(15) = log(C)
log(v/15) = -3.0*t Or
v =15 e^-3.0*t
Now v = dx/dt = 15*e^-3.0*t
Or dx= 15*e^-3.0*t*dt
Find the integration. To find the constant C, put x=0 for t =0.
thanks, that helps a lot
  • · Replies 38 ·
