Calculating Time and Distance in a Constant Velocity Sprinting Problem
The discussion revolves around a physics problem related to calculating time and distance for a sprinter running a 100 m dash, assuming constant acceleration to top speed followed by constant velocity. The original poster is struggling with unrealistic time calculations and seeks assistance in determining the total time for the sprint.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate total time using the sprinter's top speed and acceleration but finds the results unrealistic. They express confusion about the necessary information and calculations, including using the Pythagorean Theorem and average velocity.
Some participants are engaging by prompting the original poster to clarify their calculations and consider average velocity and remaining distance. There is an ongoing exploration of the problem without a clear consensus or resolution yet.
The original poster notes a lack of sufficient information to complete the problem, indicating potential constraints in the provided data or assumptions about the model being used.
bbauer2
This is probably very simple, but it's causing me problems. I keep coming up with VERY unrealistic times. Any help would be greatly appreciated!
One simple model for a person running the 100 m dash is to assume the sprinter runs with constant acceleration until reaching top speed, then maintains that speed through the finish line.
If a sprinter reaches his top speed of 11.3 m/s in 2.54 s, what will be his total time?
What have you come up with so far?
Because I have no idea where to start, I keep trying to do it mathematically. Like, 100/11.3 and then adding or subtracting the 2.54 seconds. I also tried drawing it out in a graph. When I did that I found myself in the same place. Not enough information to finish anything! I know that the equation is the change in velocity/change in time.
I got 4.45m/s^2 for the first velocity, but that doesn't seem right. I just graphed it and used Pythagorean Theorem. That would mean he ran 3.65 m at 4.45m/s^2 before reaching 11.3 m/s^2 for the other 96.35 yards. Then if you try to do Pythagorean Theorem again, it doesn't work. The hypotenuse is 11.3 and the height is 96.35. I am really stuck!
Displacement = Average velocity x time.
You know the sprinter's initial velocity and maximum velocity.
What is the average velocity and displacement?
Next what is the remaining distance? How much time he takes to run this with the maximum velocity?
