Complex analysis / Using analyticity of f to prove f is constant
The discussion revolves around a problem in complex analysis, specifically addressing the conditions under which an analytic function is constant when its modulus is constant on a domain in the complex plane.
  • Participants explore the implications of the hint involving the function f* and its relationship to the analyticity of f. There are attempts to apply the Cauchy-Riemann equations to derive conditions on the partial derivatives of the real and imaginary parts of f.
Some participants have made progress in understanding the problem and have identified connections between the Cauchy-Riemann equations and the constancy of the function. However, questions remain about the necessity of the modulus condition and its role in proving analyticity.
There is a noted complexity in the discussion regarding the analyticity of the function f* and the implications of the modulus being constant. Some participants express uncertainty about the relevance of the modulus condition in their reasoning.
AxiomOfChoice
I'm supposed to show that, if [itex]f[/itex] is analytic and [itex]|f|[/itex] is constant on a domain [itex]D \subset \mathbb{C}[/itex], [itex]f[/itex] is constant.
The hint is to write [itex]f^* = |f|^2 / f[/itex]. I might also need to use the fact that if [itex]f^*[/itex] is analytic too, then [itex]f[/itex] is constant.
Well, I followed the hint, and I fail to see how it helps at all. Given the hypotheses of the problem, I guess we know [itex]f^* = A / f[/itex] for some [itex]A > 0[/itex], but this doesn't strike me as particularly useful. Writing [itex]f = u(x,y) + i v(x,y)[/itex] only seems to complicate things, but don't I eventually have to do this? I'm guessing I'm supposed to use the Cauchy-Riemann Equations together, in some way, with the fact (proved in my text) that if [itex]h(x,y)[/itex] is a real-valued function that satisfies [itex]\nabla h = 0[/itex] on a domain, then [itex]h[/itex] is constant on that domain. But taking partial derivatives and trying to use [itex]u_x = v_y[/itex] and [itex]u_y = -v_x[/itex] just makes things messy.
You've got all the ingredients in front of you. If f=u+iv is analytic then f*=(u-iv)=A/f is also analytic. Write out the Cauchy-Riemann equations for both f and f*. What do they tell you about the partial derivatives of u and v?
Right now, I've got a system of equations for [itex]f = u+iv[/itex]: (1) [itex]uu_x = vv_x[/itex] and (2) [itex]uu_y = vv_y[/itex]. These came from [itex]u^2 + v^2 =[/itex] Constant. But I've got to show that [itex]u_x = u_y = 0[/itex] from this and [itex]u_x = v_y[/itex], [itex]u_y = -v_x[/itex]. Any hints? I still can't quite get there...
I already gave you a hint. f=u+iv and f*=u-iv are analytic. Use Cauchy-Riemann on both of them.
You did. Sorry. I'll do that :)
I figured it out. Thanks! That was very helpful.
well i figured it out using the hint too,but i didn't have to use the fact that modulus of f is constant on D.i just used the cauchy-riemann eqns from f=u+iv;
du/dx=dv/dy and from f*=u-iv; du/dx=-dv/dy hence du/dx =0, and found the partial derivatives to be zero and so f has to be constant.so where do we use the modulus of f being constant?is it when we show the analyticity of f*?
maybe it's something like that if f is analytic then 1/f is also analytic so f*=a.1/f is also analytic where a is modulus of f.but i don't know anything about the analyticity of 1/f and can't we just prove it using u and v?
-it became kind of long and sort of complicated so sorry if it's not understandable.
Yes, you use |f|=constant to prove f* is analytic. The problem is that |f| isn't generally an analytic function. A constant IS analytic.
but i don't know anything about the analyticity of 1/f and can't we just prove it using u and v?p
You should know something about the analyticity of f! Just from the normal quotient rule that you have from real analysis
In general: If |f| is not constant, then it's probably not analytic. Also f* is almost never analytic, you just have a very special case here (in fact you can show that the function that takes z to its complex conjugate is not analytic)
yes,this is really easy with quotient rule.thanks for the help!
  • · Replies 17 ·
