Register to reply
Angle of Photon after Compton Scattering
by Prologue
Tags: angle, compton, photon, scattering
Share this thread:
Prologue
#1
Sep13-09, 11:22 AM
P: 185
A photon whose energy equals the rest energy of the electron undergoes a Compton collision with an electron if the electron moves off at an angle of 40 degrees with the original photon direction, what is the energy of the scattered photon.
2. Relevant equations
E2 = (m0c2)2 + (pc)2
[tex]\lambda'=\lambda_{c}(1-cos\phi)+\lambda[/tex]
3. The attempt at a solution
This problem has been bothering me for a while. I have tried several methods of solution but they all seem too complicated. One successful version (yet actually solved with a calculator) is this:
[tex]\theta=-40^{o}[/tex]
[tex]P_{x}=\frac{h}{\lambda}=\frac{h}{\lambda'}cos\phi+P_{e}cos\theta[/tex]
[tex]P_{y}=0=\frac{h}{\lambda'}sin\phi+P_{e}sin\theta[/tex]
Solve for the terms involving theta and divide the equations to eliminate the momentum of the electron
[tex]tan\theta=\frac{\frac{h}{\lambda'}sin\phi}{\frac{h}{\lambda'}cos\phi-\frac{h}{\lambda}}[/tex]
Then substitute in for lambda prime using the Compton equation to get
[tex]tan\theta=\frac{\frac{h}{\lambda_{c}(1-cos\phi)+\lambda}sin\phi}{\frac{h}{\lambda_{c}(1-cos\phi)+\lambda}cos\phi-\frac{h}{\lambda}}[/tex]
Now you have an equation involving only phi as a variable and 'can' solve for it, I had to use a calculator though. Is there a better method or a way to solve this equation analytically?
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
kuruman
#2
Sep13-09, 12:22 PM
HW Helper
PF Gold
kuruman's Avatar
P: 3,442
Are both angles theta and phi known? The statement of the problem leaves that ambiguous.
Prologue
#3
Sep13-09, 12:32 PM
P: 185
Sorry I was going to have to put some degree thing in there and just forgot to by the time I finished. It is fixed now. The angle of the electron is known, but the angle of the photon is not.
kuruman
#4
Sep13-09, 12:38 PM
HW Helper
PF Gold
kuruman's Avatar
P: 3,442
OK, but why are you looking for lambda? The scattered photon has wavelength lambda prime. You know what lambda is because you have the energy of the initial photon. You need to eliminate angle phi from the equation.
Prologue
#5
Sep13-09, 05:21 PM
P: 185
Quote Quote by kuruman View Post
You are completely right. I just typed the wrong thing and didn't realize it. We need phi, then we can figure out lambda prime.
Prologue
#6
Sep15-09, 11:21 PM
P: 185
Any insight?
kuruman
#7
Sep16-09, 06:01 AM
HW Helper
PF Gold
kuruman's Avatar
P: 3,442
It is easier to eliminate φ rather than "finding" it. Go back to your momentum conservation equations. Isolate momentum components, i.e. write
pesinφ = ...
pecosφ = ...
Square both sides of each equation, then add them. You will be left with pe2 on the left. What can you do about that?
Prologue
#8
Sep16-09, 10:09 AM
P: 185
Those terms aren't in the equation. They are sin and cos of theta not phi. If I were to isolate the terms P_ecos and P_esin, then square and add it eliminates theta and leaves this
[tex]P_{e}^{2}=\frac{h^{2}}{\lambda'^{2}}+\frac{h^{2}}{\lambda^{2}}-\frac{2h}{\lambda'}cos\phi[/tex]
Which gives us P_e squared as a function of phi. Basically the same type of relationship we had with the momentum equations, nothing new because we knew theta to begin with.
If I try the same approach with the phi terms we get
[tex]P_{e}^{2}-2P_{e}cos\theta+(\frac{h^{2}}{\lambda^{2}}-\frac{h^{2}}{\lambda'^{2}})=0[/tex]
Which is a quadratic in P_e, if we solve that we get
[tex]P_{e}=cos\theta+(4cos^{2}\theta-4(\frac{h^{2}}{\lambda^{2}}-\frac{h^{2}}{\lambda'^{2}}))^{1/2},cos\theta-(4cos^{2}\theta-4(\frac{h^{2}}{\lambda^{2}}-\frac{h^{2}}{\lambda'^{2}}))^{1/2}[/tex]
But this is a function of lambda prime which means it is a function of phi through the compton relation. It doesn't seem like we accomplished anything.
kuruman
#9
Sep16-09, 10:39 AM
HW Helper
PF Gold
kuruman's Avatar
P: 3,442
Quote Quote by Prologue View Post
[tex]\frac{h}{\lambda}=\frac{h}{\lambda'}cos\phi+P_{e}cos\theta[/tex]
[tex]0=\frac{h}{\lambda'}sin\phi+P_{e}sin\theta[/tex]
Ignore the Compton formula. I am referring to your own equations that you posted. You can write
sinφ = ...
cosφ = ...
(I was wrong adding the pe up front), square and add. This gives one equation with two unknowns, pe and λ'. The energy conservation equation will allow you to eliminate pe and you will end up with an equation in λ' only. Actually, since you are asked to find the energy of the scattered photon, I would replace 1/λ' with E'/hc in my expressions and solve for E'.
zibaba
#10
Mar31-10, 06:21 PM
P: 1
Through what angle must a 2x10^5 ev be scattered by free electron so that the photon looses 10% of its energy
Register to reply
Related Discussions
Compton scattering: electron absorbs then emits a photon? Quantum Physics 13
Compton Scattering Advanced Physics Homework 0
Compton Scattering General Physics 1
Compton effect with no scattering angle Advanced Physics Homework 4
Compton photon scattering Advanced Physics Homework 1
