Linear Algebra - Linear Transformations, Change of Basis
The discussion revolves around proving a formula related to linear transformations and change of basis in linear algebra. The original poster seeks assistance with the expression [T]C = P(C<-B)[T]B.P(C<-B)-1, where B and C are bases in a finite-dimensional vector space V, and T is a linear transformation.
  • Participants discuss the relationship between vector representations in different bases and the implications of linear transformations being independent of the basis. There are attempts to manipulate the transformation and basis change matrices, and questions arise regarding the necessity of independence from the basis in the context of linear transformations.
The discussion is ongoing, with participants exploring various aspects of the problem. Some have provided insights into the definitions and properties of linear transformations, while others are questioning the assumptions underlying the problem. There is no explicit consensus yet, but productive lines of inquiry are being pursued.
Participants are navigating the complexities of linear transformations and their representations in different bases, with some expressing uncertainty about the role of bases in the definition of linear transformations. The original poster's request for proof indicates a focus on formal mathematical reasoning.
sassie
I need to prove this formula, but I'm not sure how to prove it.[T]C = P(C<-B).[T]B.P(C<-B)-1
whereby B and C are bases in finite dimensional vector space V, and T is a linear transformation. Your help is greatly appreciated!
T(x)=Ax
[x]C=P(C<-B)[x]B
Similar matrices.
T(x)=Ax
[T]C=[[T(c1)]C...[T(cn)]C
Suppose [x]B is some vector x represented in basis B and that Tx= y (independent of the basis).
Then, by definition of "PB<-C", PC<-B is P-1B<-C is so P^{-1}B<-C[x]C= [x]B.
Then TBP^{-1}B<-C[x]CxC= TB[x]B= [y]B and, finally, PB<-CTBP^{-1}B<-C[x]C= PB<-C[y]C= [y]_B.
Okay, thanks! I did manage to get something like that before, but I got stuck because I didn't do the tx=y thing.
But may I ask, why does Tx= y need to be independent of the basis?
A linear transformation, T, is a function from vector space U to vector space V such that T(au+bv)= aT(u)+ bT(v). There are no "bases" required for its definition. Bases are only necessary to write the linear transformation as a matrix.
  • · Replies 18 ·
