Help with conditional probabilty
  • Context: Undergrad
  • Thread starter Thread starter BlueScreenOD
    Conditional
The discussion revolves around a conditional probability problem involving a breath analyzer test for drunkenness. Participants explore the relationships between various probabilities, including the sensitivity and specificity of the test, and how these relate to the positive predictive value and the likelihood of a suspect being drunk given a positive test result. The scope includes mathematical reasoning and homework-related inquiries.
  • Homework-related
  • BlueScreenOD presents a problem involving events A (breath analyzer indicates drunk) and B (suspect is drunk), seeking help with conditional probabilities.
  • Some participants suggest using Bayes' Theorem to approach the problem, while others provide alternative methods such as tree diagrams.
  • Elucidus discusses the definitions of sensitivity and specificity in relation to the problem, noting that P(A|B) is the sensitivity and P(A'|B') is the specificity.
  • Elucidus calculates P(B'|A) and P(B|A) based on different values of p, suggesting that a high accuracy is needed for the test to yield a high positive predictive value.
  • There are differing interpretations of earlier calculations, with some participants questioning the correctness of the steps taken by others.
  • Participants express uncertainty about the correctness of their calculations and the implications of their results, particularly regarding the values of P(A) and the conditions under which certain equations hold true.
Participants do not reach a consensus on the calculations and interpretations presented. There are multiple competing views on the correctness of the approaches and results, with some participants agreeing on certain values while others challenge the reasoning behind them.
Some participants note that P(A|B) does not generally equal 1 - P(A|B'), but this relationship holds in this specific case due to equal sensitivity and specificity. There are also mentions of potential errors in earlier calculations that could affect the results.
This discussion may be useful for students learning about conditional probability, Bayes' Theorem, and the application of probability in real-world scenarios, particularly in the context of testing and diagnostics.
BlueScreenOD
I've been struggling for a good couple hours on the below, and I was hoping someone might be able to push me in the right direction...
"A" represents the event "the breath analyzer indicates the suspect is drunk" and "B" represents the event "the suspect is drunk." On a given Saturday night, about 5% of drivers are known to be drunk.
P(A | B) = P(compliment of A | complement of B) = p
a.) determine P(compliment of B | A) if p = .95
b.) how big should p be so that P(B | A) = 0.9?
From the problem I can deduce that P(B) is .05 and P(compliment of A | B) = (A | compliment of B) = .05, but how can I put P(compliment of B | A) in terms of P(A | B)? Any help would be greatly appreciated.
Hi BlueScreenOD, welcome to PF. Are you familiar with Bayes' Theorem?
(And it's "complement" :smile:)
Thanks for your reply Mapes!
This is what I have so far, could be kind enough to tell me if this looks right? I'll use ^ for the intersection operator.
P(A | B) = 1 - P(A | complement B)
because P(complement A | complement B) = 1 - P(A | complement B)
P(A ^ B) / P(B) = 1 - P(A ^ complement B)
because P(A | B) = P(A ^ B) P(B)
P(A ^ B) / .05 + P(A ^ complement B) / .95 = 1
19 * P(A ^ B) + P (A ^ complement B) = .95
P(A ^ B) + P (A ^ complement B) = .95 - 18 * P(A ^ B)
P(A) = .95 - 18 * P(A ^ B)
because (A ^ B) + P (A ^ complement B) is P(A)
P(A) = .95 - 18 * [P(A | B) * P(B)]
P(A) = 0.095
The value strikes me as high, though... am i screwing something up?
Nope, looks good. The breathalyzer comes up positive nearly all the time for the 5% drunk people, and 5% for the general population. So it comes up positive about 10% of the time.
Note, though, that P(A) = P(A|B)P(B) + P(A|notB)P(notB), so you can get to this result a bit easier.
Wow, that's a much simpler calculation. Thanks for your help!
I've done the work for the two questions and I'm getting different values than in earlier posts.
Note for reference that P(A|B) is the sensitivity of the test and P(A'|B') is the specificity of the test, both of which are frequently thought of as measures of accuracy. P(B|A) is the positive predictive value and P(B'|A') is the negative predictive value.
If one creates a tree diagram with initial branches to B and B' (the complement of B) and then from each of those, branches to A and A' we get four terminals and probabilities:
P(BA) = 0.05p
P(BA') = 0.05(1 - p)
P(B'A) = 0.95(1 - p)
P(B'A') = 0.95p
This gives
P(A) = 0.05p + 0.95(1 - p) = 0.95 - 0.9p
P(A') = 0.05(1 - p) + 0.95p = 0.05 + 0.9p
Q1) Find P(B'|A) if p = 0.95
P(B'|A) = P(B'A)/P(A) = (0.95 - 0.95p)/(0.95 - 0.9p)
When p = 0.95 this equals 0.5. This says that the likelihood that a person with a positve breathalyzer test actually being drunk is 50%, assuming an accuracy of 95%.
Q2) Find p if P(B|A) = 0.9.
P(B|A) = P(BA)/P(A) = (0.05p)/(0.95 - 0.9p)
Solving this against 0.9 gives p = 0.994186...
So in order for the test to have a positive predictive value of at least 90%, the accuracy of the test needs to be at least 99.4% accurate.
In general when the rate of incidence of a particular condition is low, tests need to be very accurate in order to have high positive predictive value.
--Elucidus
Your P(A) is 0.095, which is the same as BlueScreenOD got and was as far as BlueScreenOD got. It's more helpful if you help the poster figure out the homework problem rather than just posting the answer.
When I first read through BlueScreenOD's attempt, I thought I saw errors - which would lead to erroneous answers. (BlueScreenOD's value for P(A) is correct for part 1 as you say - I missed that.)
In general P(A|B) does not equal 1 - P(A|B'), but as it turns out, for this particular situation it does since the sensitivity and specificity are equal. Some of the other equations are also generally false. This is what lead me to reexamine the problem.
I also thought that a full solution had been attempted and was in error (which is not the case). I did not intend to spoil the opportunity and I apologize (at 11:30pm I probably wasn't as sharp as I should've been :)
As a final helpful hint though: these problems are often be easily solved with a tree diagram, but Bayes' Rule works as well.
--Elucidus
I ended up with the same answers. Thank you both for your help!
I haven't learned that technique yet, but I'll have to look into it.
  • · Replies 65 ·
13K
