Intersize Particle Interaction
In summary,Can an electron traveling near the speed of light knock a proton or neutron out of a nucleus?Yes, it can.
gonegahgah
376
Yes, it can.
Thanks Bob. I see that you are a theoretical physicist. I am having trouble finding any info on this. Do you know the proper web search parameters to get this info or of any specific info that is available on the web so that I can study this? Thanks.
I am not good at this kind of phenomena. It may be called element transmutation, nucleus excitation/splitting, deep inelastic scattering, or so. Sorry.
Hi gonegahgah-
Most of the electron-nuclear reactions go via a single-photon coupling, so experimenters use electrons to produce a bremsstrahlung beam and measure photo-nuclear reactions. Most reaction channels are gamma-neutron, with thresholds being around 20 MeV for low-Z and 6 to 8 MeV for high-Z targets. Some targets, like aluminum-27 go via other channels, like 2p n, to sodium 24. At high Z, cross sections are over 1 barn; for low Z maybe 10 to 20 millibarns. Bremsstrahlung in air produces a lot of nitrogen-13 and oxygen-15, both short half lives.
Bob S
Thanks Bob & Bob.
I looked up those terms you suggested Bob4.
Nuclear transmutation seems to involved a lot more energy than a single electron on its own can offer.
Nucleus excitation seems to be more about capture of ions and electrons rather than knocking out protons.
Nucleus splitting seems to involve sending in neutrons; not electrons.
The deep inelastic scattering did involved firing electrons into the nucleus but these don't seem to have dislodged the protons or neutrons; only the electrons themselves emerged.
I might be wrong on those of course so please correct me.
At the moment I'm not sure which of these might apply or if something else might apply.
Thanks
Hi gonegahgah-
Nuclear transmutation is done primarily by neutron capture. neutrons are produced primarily by neutron capture and proton bombardment, and less efficiently by electron bombardment (via single photon exchange).
Atomic (not nuclear) excitation is more about ion and electron capture.
Nuclear splitting (fission) is done primarily by neutrons.
Electron elastic scattering was used to measure nuclear sizes. Electron deep inelastic scattering led to discopvery of partons, now called quarks.
Bob S
Thanks BobS.
It is also the photons I am curious about as well.
I'm trying to get a feel for the intersize particle 'heftiness'.
Electrons have about 1/1836 the mass of of a proton (1/1839 of a neutron).
This makes it harder for electrons to push protons around I imagine than vice-versa; the electrons go where the proton goes; not vice-versa.
When hydrogen fuses to helium the conversion of mass to energy is about 1/142 the mass (a site said 0.7%; that is 1/142 isn't it?).
More mass than that contained in an electron is converted is it? Wow!
But that doesn't correspond to a single photon does it?
Afterall normal light scattering due to 'electron excitation and photon re-emission' doesn't correspond anywhere near that relative quantity of energy.
gonegahgah said:
Thanks BobS.
The electron and bremsstrahlung photon energies that we are talking about here for nuclear transmutation are in the MeV region, so this energy corresponds to binding energies of nucleons. The deuteron binding (dissociation) energy is about 2.2 MeV, for example. The normal light scattering and "electron excitation and photon re-emission" you mention is an atomic, not nuclear, excitation process.
Thanks BobS. I'm okay with that. I was just mainly wondering about the energy released through fusion. All that large amount of energy released from a single instance of fusion isn't released as a single photon is it? That would be one big photon if it was?
Fusion reactions usually yield strong-interaction products (neutrons, etc) rather than electromagnetic (photons). For example, the D-D fusion yields a tritium or helium-3 plus a neutron (2.5 to 3 MeV), and the D-T fusion yields an alpha particle plus a 14.1 Mev neutron.
Bob S
1. What is interparticle interaction?
Interparticle interaction refers to the forces and interactions that occur between particles in a system, such as atoms, molecules, or larger particles. These interactions can include attractive forces, repulsive forces, and electrostatic interactions.
2. Why is interparticle interaction important?
Interparticle interactions play a crucial role in many physical, chemical, and biological processes. They determine the structure, properties, and behavior of materials, and can impact the overall performance of a system. Understanding and controlling interparticle interactions is essential in fields such as materials science, nanotechnology, and biophysics.
3. How do interparticle interactions affect the behavior of colloidal systems?
Colloidal systems, which consist of small particles dispersed in a medium, are highly influenced by interparticle interactions. These interactions can cause particles to aggregate or repel each other, leading to changes in the stability, rheology, and optical properties of the system. Understanding and controlling interparticle interactions is crucial in the design and development of colloidal systems for various applications.
4. What are the factors that influence interparticle interactions?
The strength and type of interparticle interactions are influenced by various factors, including the size, shape, and surface chemistry of the particles, the properties of the surrounding medium, and the distance between particles. The presence of external forces, such as electric or magnetic fields, can also affect interparticle interactions.
5. How can we study and manipulate interparticle interactions?
There are various experimental techniques and theoretical models used to study and manipulate interparticle interactions. These include microscopy, spectroscopy, scattering techniques, and computer simulations. Manipulating interparticle interactions can be achieved through techniques such as surface modification, controlling the surrounding environment, and using external fields to alter the forces between particles.
