Number Base System: Solving the Radix/Base
  • Thread starter Thread starter tnutty
    Base System
The discussion revolves around determining the base (radix) used in two mathematical operations: the addition of four instances of 1234 and the multiplication of 19 and 18. Participants explore the implications of the base on the results of these operations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessary conditions for the base in both operations, with some suggesting to check specific bases starting from 5 for addition and 10 for multiplication. There are attempts to express the operations in terms of an unknown base "r" and to verify results through conversion to base-10 equivalents.
Some participants have identified potential bases for the operations, with one confirming that the base for part (a) is 5. However, there is uncertainty regarding part (b), with various bases being tested without reaching a definitive conclusion. Guidance has been offered on how to approach the problem by converting numbers into base-10 equivalents.
Participants note that the numbers involved in the multiplication must be in the same base as the result, and there is an emphasis on checking assumptions about the base being even or odd. The discussion reflects a collaborative effort to explore different bases and their implications on the operations.
tnutty
This really isn't a calc question so forgive me.
Determine which base(radix) is used in the following operation :
a ) 1234 + 1234 + 1234 + 1234 = 11101
b ) 19 * 18 = 297
I know the answer to a but am not sure how to get it.
What I see is the for a) the answer has to be greater than base 4, and for b) it has
to be radix >=10.
Is there some tricks that could help me figure out what base is in general a expression is on?
For a, yes, the base has to be larger than 4, so use the fact that 4 + 4 + 4 + 4 = base + 1 or maybe 2* base + 1. Check the addition in a few bases (probably not an even base), starting with 5.
For b, I agree that the base is probably larger than 10. Again try a few bases and see if you can find one for which 9 * 8 = base + 7. Since you're getting a unit's place of 7, it's probably not an even base.
For A its 5, but I can't seem to figure out part B.
This is what I got :
let "r" be the base.
(9*8)r = ?
r = x | result = y | (1|0)
11 | 68 | 11 * 6 = 66, left over 2. False
13 | 57 | 13 * 4 = 52, left over 5, False
And it goes on.
What I did was 9*8 = 72. In base 10. Then divide 72 by different bases to see if it matched up.
wait is r = 13 correct?
(9*8)r = ?
And it goes on.
Yes, the radix is 13 in part (b). Can you show why?
--Elucidus
Keep in mind that the numbers in the product are in the same base as the answer, so what you have for b is 19r * 18r = 297r.
What I did was to make an educated guess as to the base, and then convert all three numbers into their base-10 equivalents and check the multiplication in that more familiar base.
I was thinking of doing that as well.
Lets see :
19r * 18r = 297r
I know its not base 10, but from (base 10) 9*8 = 72
Now I can use this to convert into other base and check accordingly.
13*5 = 65;
72 - 65 = 7
So 7 is left over and even number of 13 is carried onto the next step. Ah, its just
like you said, look for "base + 7".
It would be nice if someone could offer alternative solution.
  • · Replies 26 ·
