Vertical Circles and Non-Uniform Circular Motion
The discussion revolves around the dynamics of vertical circular motion, specifically focusing on the minimum velocity required for an object to complete a circular path without tension in the supporting rope or normal force at the peak of the motion. Participants explore the implications of gravitational force and centripetal force in this context.
  • Participants discuss the conditions under which tension in the rope becomes zero at the top of the circle and question the role of gravitational force in maintaining circular motion. They also consider the implications of inertia and Newton's laws in these scenarios.
The conversation is ongoing, with participants seeking clarification on the reasoning behind the forces acting on the object at various points in the circular path. Some have offered insights into free body diagrams and the relationship between forces, while others are questioning their assumptions and seeking corrections.
Participants are grappling with the concept of minimum velocity in circular motion and the conditions under which forces such as tension and normal force can approach zero. There is an emphasis on understanding the dynamics at both the top and bottom of the circular path.
MechaMZ
If we wanted to calculate the minimum or critical velocity needed for the block to just be able to pass through the top of the circle without the rope sagging then we would start by letting the tension in the rope approaches zero.
http://img147.imageshack.us/img147/6826/3c6634a694b3434387bd810.gif http://img147.imageshack.us/img147/7402/3c46cefd59484d479f07621.gif http://img147.imageshack.us/img147/4192/5ee60dbd561d4cca96b54d5.gif
why must we letting the tension in the rope approaches zero without the rope sagging? what is the force support the object goes to the top without pulling down by gravitation force? was it because of the Newton first law, so the object wanted to remain straight line but pulling towards to the centre by centripetal force?
http://img225.imageshack.us/img225/4176/p621.gif
At point B, why the normal reaction force is or need to be zero? isn't the mg is acting on the track?
will it due to the inertia of the roller-coaster tends to go straight yet pulling back the centripetal force,mg. hence, the contact force to the track is reduced and almost zero since the roller-coaster is really fast.
Hope somebody could answer these to me, thank you
You can answer your questions by drawing a free body diagram for each of the moving objects (the block / roller coaster rider). The forces acting on the block/rider are gravity and the mechanical force of the rope/car. Since gravity cannot be reduced, the minimum force on the object would occur when the mechanical force is at a minimum.
In the rope case, analyse the forces on the object at the top of the loop (let the positive direction be down):
[tex]\vec{F} = \vec{T}+ \vec{F_g} = \vec{T} + m\vec{g} = m\vec{a}[/tex]
where a is the net acceleration. What is the net acceleration and net force (hint: it is a function of v, the tangential speed)?Now, what is the value of v if T = 0 and the object is still traveling in a circle?
What happens if v is less than this speed? Does the object still travel in a circle?
AM
i know how to do it but i don't understand why to do it in this way. why at the maximum point, the tension is zero? and happens the same while the roller-coaster at the peak point, the normal reaction is zero as well, even the roller-coaster is not upside-down.
are all these due to inertia by Newton second law? object tends to remain their original state, so lesser contact force to the track or rope.
is my assumption right or wrong, could somebody please correct me =)
Since the object goes in a circle, the Tension + mg will always equal mv^2/R. The tension cannot go below 0 and mg cannot change, so the minimum force is mg. This means that the minimum circular speed is [itex]\sqrt{gR}[/itex]. If v is less than this what happens at the top?
AM
AM
thanks, so how about the second situation at B
At[/URL] the bottom, the forces are different. What additional force is there? At the top, what keeps the car moving in a circle? (hint: the net force is the sum of two forces acting in opposite directions). What happens if the force required to keep the car moving in a circular arc exceeds mg?
AM
