| Thread Closed |
Newton-Raphson help! |
Share Thread | Thread Tools |
| Sep16-09, 11:23 PM | #1 |
[Divide and average Method] Square root of 2 was computed using the formula Xi+1 = 1/2 ( Xi + 2/Xi).------------ (1) Derive this method from the Newton-Raphson Formula 2. Relevant equations 3. The attempt at a solution Im boggled at how to derive this solution. The equation for Newton Raphson is F'(Xi) = (F(Xi) - 0) / Xi -(Xi+1) ------------- (2) which can be rearranged to Xi+1 = Xi - F(Xi) / F'(Xi)--------- (3) does this mean that i take the derivative of the equation (1)? (Xi+1)' =1/2(Xi+2/Xi) = ?? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep17-09, 03:10 PM | #2 |
[tex]x^2 = 2[/tex] or [tex]x = \frac{2}{x}[/tex] So, [tex]f(x) = \frac{2}{x}[/tex] Derive your equations from there. |
| Sep17-09, 05:24 PM | #3 |
I still dont get it, do i take the derivative of 2/x?
that would be f(x)'=-2(1/x^2) |
| Sep17-09, 07:09 PM | #4 |
| Sep17-09, 11:01 PM | #5 |
/s |
| Sep17-09, 11:03 PM | #6 |
I am having the same problem.
Newton Raphson method: Xof(i+1) = xi - f(x)/f(x)' it is used to find roots by iteration |
| Sep18-09, 04:41 AM | #7 |
Calculate f'(x). Choose a starting value for x0. If y - f(x0) < tolerance then end else Calculate x1 using Newton-Raphson formula. Iterate |
| Sep19-09, 07:27 AM | #8 |
I think there is sufficient confusion amoung these posts to warrent another (hopefully non-confusing) post
thedc: For Newton-Raphson, you are looking for the zero of a function (F), hence, you need to express the function (F) such that F(x) = 0. In your original post, you desire to find the answer to [itex]x[/itex] for [itex]x = \sqrt{2}[/itex]. Consider the more genral solution for [itex]x[/itex] with [itex]x = \sqrt{A}[/itex] for some positive [itex]A[/itex]. Question: How can we express a function, [itex]F(x)[/itex], such that it results in [itex]F(x)=0[/itex] for this problem? Answer: Look at the [itex]x = \sqrt{A}[/itex]. This is really the same as finding [itex]x^2[/itex] such that [itex]x^2 = A[/itex]. Hence, one selection of [itex]F(x)[/itex] might be [itex]F(x) = x^2 - A=0[/itex]. This is the "F" that is needed in the N-R method. The iterates for the solution of x are as follows: [tex] x_{\nu+1} = x_{\nu}-\frac{F(x_{\nu})}{F'(x_{\nu})} [/tex] Here, [itex]F'(x)[/itex] is shorthand to mean [itex]\frac{d\,}{dx}F(x)[/itex]. Also, in your case, the vale of A is A=2. You will need an initial estimate [itex]x_{0}[/itex] to start this procedure. The key to achieve the end goal of your exercise is to do some algebra on the resulting iterate expresion once you take the derivative of F and substitute it into the expression. Hope this helps. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Newton-Raphson help!
| Newton-Raphson in Visual Basic 6 | Programming & Comp Sci | 17 | ||
| Help with Newton-Raphson Method | Engineering, Comp Sci, & Technology Homework | 9 | ||
| When Newton Raphson Fails | Calculus & Beyond Homework | 4 | ||
| Newton-Raphson question | Calculus | 11 | ||
| Newton-Raphson method for y=1/f(x) | General Math | 2 | ||
