How Does Polarizer Orientation Affect Light Intensity?
The discussion centers on calculating the intensity of light after passing through two polarizers with an angle of θ = 40.0° between their axes. The initial intensity of unpolarized light from an incandescent lamp is 176 Cd. Using Malus' Law, the correct approach involves applying the formula I = Io * cos²(θ) for each polarizer sequentially, starting with the initial intensity. The confusion arises from incorrect initial values and angles used in calculations, leading to erroneous results.
  • Understanding of Malus' Law in optics
  • Familiarity with the concept of light intensity and measurement in candelas (Cd)
  • Basic knowledge of polarizers and their function
  • Ability to perform trigonometric calculations
  • Review the application of Malus' Law in multiple polarizer scenarios
  • Study the effects of varying angles between polarizers on light intensity
  • Explore practical experiments with polarizers to measure light intensity
  • Learn about the properties of unpolarized versus polarized light
Students and professionals in physics, optical engineering, and anyone interested in the principles of light behavior and polarization effects.
Babylady247
Unpolarized light from an incandescent lamp has an intensity 176 Cd as measured by a light meter. What is the intensity reading on the meter when two ideal are inserted between the bulb and the meter with their axis of polarization making an angle of θ = 40.0° relative to each other? Express your answer in Cd.
am having some trouble with this problem. Here's what I have so far:
Known info:
Io=28 Cd
Theta= 6o
There are two polarizers, so theta1=6 and theta2=6
Equations:
I= Io/2
Malus' Law: I= Iocos^2theta
Work:
I used this to try and solve and it is wrong...
I = 28/2
I=14
Then
I = 28(cos6)^2 which = 27.7 (at theta1)
but there are two polarizers so 27.7 becomes the new Io for theta2
I=27.7(cos6)^2 which =27.4
So you add them right? 27.7+27.4 which = 55.1?
Where am I getting confused?
Welcome to PF.
For starters, the problem statement says 176 Cd and 40.0 degrees. Why are you using 28 Cd and 6 degrees when you work out the problem?
  • · Replies 25 ·
11K
