| Thread Closed |
Converting noise into electrical energy |
Share Thread | Thread Tools |
| Feb25-10, 12:36 AM | #18 |
It's hard to tell you, since the only info about the "sonea" in the english language was written by someone who doesn't know what a dB is and who confuses power and energy.
| Feb25-10, 12:44 AM | #19 |
^sir willem2 do you have an idea about sound to electrical energy?we want to at least light a LED
| Feb25-10, 01:05 AM | #20 |
| Feb25-10, 01:18 AM | #21 |
how far did you try to make a circuit that can convert sound to electrical energy
| Feb25-10, 01:23 AM | #22 |
i didnt do anything else apart documentation. I talked with the one whom i wanted to be my supervisor and told me that it is a higher level project and that it was not more efficient in my country. But what i know the key is about the piezoelectric effect. And furthermore, any vibrations (mechanical energy) can be converted into electricity through a transducer. This is even how microphones work. I wish i can help you as i can.
| Feb25-10, 01:26 AM | #23 |
wew that is our big problem our thesis is about sound and our dean/prof is strict about the title that we cant use vibrations as an alternate for the sound energy
| Feb25-10, 01:31 AM | #24 |
look, i have a friend who is working on a microphone, i will ask him and tell you more details, coz i think your project seems to be a modification of a microphone because you will be dealing with louder sounds (eg. from industries' machines) and you will not need higher amplifiers, right? Here is my email adress if you still want to contact me giray03@yahoo.fr
| Feb25-10, 01:33 AM | #25 |
thanks for that...yes i really need sum1s advise we are lacking out of time and im only a student need sum1 who has more knowledge about this topics add me up>soulstriker29@yahoo.com
| Mar30-11, 09:20 AM | #26 |
i m also working on this project.would you help me in all stages from beagining to last step |
| Mar30-11, 09:32 AM | #27 |
Best wishes my friend. P.S: Would you also refer to the #8 comment of this thread. Loren Booda has talked about something like "Magnetic Damper" and I think it may be interesting. Please check on it. |
| Mar30-11, 09:50 AM | #28 |
If you shout into a loudspeaker cone, the electrical energy it will produce can drive a distant earphone. With a jet engine a few metres away, the energy level would be a bit higher than that but you could only intercept a small fraction of what the engine is producing.
This article - http://www.quiet.org/readings/tatum.htm gives you some idea of the flow of sound energy. 60dB, which corresponds to 'normal conversation', corresponds to 1 microWatt per square metre. 120dB is around a nearby Jet engine noise level and would correspond to just 1W per square metre. Allowing for inefficiency in any transducer you were using, this would probably end up as 0.1W of useful electrical energy. As a way of re-using 'lost' noise energy it seems to be pretty poor value, unfortunately. It is actually amazing what a very good job your ears do, when you think that 0dB corresponds roughlt to the threshold of hearing. A millionth of a normal conversation level can just be detected. |
| Mar31-11, 05:29 PM | #29 |
I have considered using crystals as a primary source for energy generation. Consider a turning fork. It is not large, nor loud, yet it can shatter glass. I am sure with the primary tone and it's harmonics, some acustic engineering and channeling it's point of critical mass or it's most effective convergent frequency; energy can be gleaned. The problem is not creating energy, the problem is increasing the yield. Once you increase the yeild of one, the same approach can be use to increase all forms of energu.
| Mar31-11, 05:48 PM | #30 |
The energy has to come from somewhere. You can't just take a small amount and output a large amount. Are you aware why a tuning fork is able to break glass? |
| Mar31-11, 05:57 PM | #31 |
You can alter the 'yield', as you put it, but not to get more out than you put in. But which are you discussing, noise production or noise reception? What are you actually trying to do with this noise? |
| Mar31-11, 06:45 PM | #32 |
I has thinking that there might be sources of sound that can be regenerative and more efficient than others. I also thought that even a small amounts of energy can be increased by using circuits like voltage doubler over and over until you reach a goal voltage..
| Mar31-11, 06:48 PM | #33 |
I have no idea what a "regenerative sound" is so I'll leave that to someone else. |
| Apr1-11, 12:41 AM | #34 |
1. What do you mean by an "efficient" source of sound?
2. In my figures for available power of sound noise, I was, of course, assuming 100% efficiency. A voltage doubler gives no more power. That's basics. |
| Thread Closed |
| Tags |
| convert, electric, energy, noise, piezo |
| Thread Tools | |
Similar Threads for: Converting noise into electrical energy
| Electrical dark, and spectrum noise. | General Physics | 1 | ||
| converting mechanical to electrical energy | Classical Physics | 2 | ||
| converting energy | Atomic, Solid State, Comp. Physics | 2 | ||
| Converting from sound to electrical energy? | General Physics | 1 | ||
| converting energy | General Physics | 14 | ||
