| Thread Closed |
home test for lead |
Share Thread | Thread Tools |
| Sep21-09, 12:03 AM | #18 |
home test for lead
| Sep22-09, 12:19 AM | #19 |
Recognitions:
Lead in its solid, elemental, form can be slowly absorbed into your body by touch. Minor contact with it here and there is generally no big deal by itself. But it accumulates in your body over time and might eventually reach dangerous levels from chronic exposure.
Although absorption of solid lead into the body is relatively slow, water-soluble lead salts on the other hand are much more readily absorbed and pose a much greater danger. It is best to only generate and use lead salts in moderation and it dispose of them through the proper channels. Many cities have an environmental-waster disposal facilities where people can bring them their waste (such as lead paint, motor oil, …., other nasty stuff that should not end up in landfills or down the drain) and they will dispose of it for you for free. This would be the preferred way for an individual to dispose of lead waste. Lead shavings also pose a greater risk compared with just a large solid lump of lead metal since there exists the possibility of breathing in some of the smaller flakes or accidentally ingesting them. So one might be wise to wear a mask and wash one’s hands thoroughly while / after handling fine flakes of lead. |
| Sep23-09, 12:45 AM | #20 |
He still hasn't determined if his lump of metal fogs unexposed film.....
It could be worse, y'know. |
| Sep23-09, 02:34 AM | #21 |
I think it's kryptonite.
| Sep23-09, 03:02 AM | #22 |
Admin
Nah, IIRC kryptonite was green.
| Sep23-09, 08:25 AM | #23 |
| Oct1-09, 08:10 AM | #24 |
OK, radioactivity: zero.
I would not have been amused to find out that I've been storing a lump of Plutonium on my office shelf.... |
| Oct1-09, 10:49 AM | #25 |
Well the good news is since it's not radioactive, it has to be one of the first 82 elements, so lead is still a possibility. Also, you don't have to worry about pesky radiation messing with your cells :)
| Oct1-09, 10:55 AM | #26 |
Admin
-- buffer calculator, concentration calculator pH calculator, stoichiometry calculator |
| Oct1-09, 12:12 PM | #27 |
Why is your sig part of the body of your message? |
| Oct1-09, 12:25 PM | #28 |
Perhaps he is referring to Bismuth (atomic # 83).
| Oct1-09, 12:31 PM | #29 |
| Oct1-09, 12:35 PM | #30 |
Same is true for Bismuth 209. Half life something like 2 X 1019 years.
| Oct1-09, 12:48 PM | #31 |
Let me rephrase. Since it's not radioactive, it is most likely one of the first 82 elements. I understand that some higher elements could fall into this category (for example, bismuth-209, as was said), but how often do these elements present themselves in such large quantities in everyday life?
| Oct1-09, 02:02 PM | #32 |
Admin
| Oct1-09, 11:08 PM | #33 |
Geez Borek, you and your exceptions :p
| Oct2-09, 02:49 AM | #34 |
Admin
They are not mine, they are around
![]() -- ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator www.ph-meter.info - ph meter, ph electrode |
| Thread Closed |
| Thread Tools | |
Similar Threads for: home test for lead
| Need help with take home test | Biology, Chemistry & Other Homework | 6 | ||
| Stuck with a problem from a take home test | Introductory Physics Homework | 2 | ||
